Support displacement
Posted by vladoff
August 21, 2019 10:24AM
Hi to every one,
I am having a problem when I print with dual heads. The support that is printed by one of them is built not in right place but 2 mm shifted that caused overlap the layers of the main object.
Can someone suggest any solution
Thank you in advance
Re: Support displacement
August 21, 2019 12:20PM
You need to adjust the tool offsets. Depending on what firmware you use, this may be an adjustment to the firmware configuration file (which for some firmwares is just a text file held on the SD card), or you may have to adjust it in the slicer.
August 21, 2019 02:51PM
Thank you for your suggestion.
I am using Simplify3d and I have not seen such an option. As for the firmware, I am not familiar with it. It is about German Reprap X400.
I thought the calibration was done by the supplier. I was trying dual heads printing for the first time.
I noticed when I select one or another head in the machine control panel, they moved to zero position,
but the zero position of the one head was displaced 2 mm aside from the zero of the other head. (sorry for my English)
August 22, 2019 01:46AM
vladoff
Actually, Simplify3D does have tool offsets. Look in the "g-code" tab. I think that its better to set it up in the firmware though, less likely to forget it.
DLC
Kits: Folgertech Kossel 2020 upgraded E3Dv6, Anet A8 upgraded E3Dv6, Tevo Tarantula enhanced parts and dual-head, TronXY X5SA Pro(E3DHemera).
Scratch: Large bed Cartesian, exchangeable heads, Linear slide Delta, Maker-Beam XL Micro Delta, 220x220CoreXY.
August 22, 2019 03:50PM
dlc60
DLC
Many thanks!!
It works!!
