TMC 2208 r sense value vary
Posted by porlock
August 25, 2019 04:59AM
I installed 2208 drivers and notices that value or sens resi
stor that is returned by M122 is not constant, sometimes is 0.18 and sometimes 0.325, when i restart my printer it could change again, or it change in random pattern is this is normal ? how to explain this ?
Edited 1 time(s). Last edit at 08/25/2019 05:04AM by porlock.
Re: TMC 2208 r sense value vary
October 23, 2019 05:40PM
Does the same happen when you run the drivers powered? I see they are now reporting 'false' under enabled. Also, did you already configure your firmware? As I see you have stealthchop disabled.
http://www.marinusdebeer.nl/
