zeepro zim still show 30 to 50 to 60 tem then zero
Posted by mohammad dwikat
August 27, 2019 04:51AM
hi
welcome my friends
I have a 3D printer from Zeepro and I have several problems
1 - First I did not know how to connect it through the Wi-Fi network because it does not show the name of the network (zim_insilization)
2 - I tried to contact them in several programs,for printing, but it did not work
Simplify3D not succ
RepetierHost not succ
3. The program that enabled me to print is a pronterface but
when click heat button the tempreture rise to 30 then dawn to zero why please help me
My Printer FEATURES & S PECIFICATIONS links
[www.manualslib.com]
machine type mendel
firmware ver marlin 1.0.28.9
thanks for all
Edited 1 time(s). Last edit at 08/27/2019 04:59AM by mohammad dwikat.
Re: zeepro zim still show 30 to 50 to 60 tem then zero
August 27, 2019 05:53AM
This is in no way shape or form a reprap, it is a commercial printer that is now obsolete since they stopped their cloud services,
It comes with two boards a A10 control board (which really has a a20 cpu on it) This is useless without the web site.
It also is meant to have a ramps inside it.
Most replace the A10 with a raspbury Pi running octoprint
[www.youtube.com]
August 27, 2019 11:30AM
ok sir thanks
but the was working ok i have to solve the problem
maybe in near future update this as you mention
is any other solution or not
very thanks
January 26, 2020 05:28AM
Take motherboard to a shop and have them solder an unpluged usb connect to the board - then use Simplify3d or Repetier to connect via the usb - either will work - I have had better luck with Repetier
[www.youtube.com]
Edited 1 time(s). Last edit at 01/26/2020 05:31AM by Charels.
