CoreXY printer, print slowly shifts / leans to the right December 08, 2019 01:56PM |
Re: CoreXY printer, print slowly shifts / leans to the right December 10, 2019 09:18AM |
Re: CoreXY printer, print slowly shifts / leans to the right December 11, 2019 01:31AM |
Re: CoreXY printer, print slowly shifts / leans to the right December 12, 2019 03:18AM |
Re: CoreXY printer, print slowly shifts / leans to the right December 12, 2019 07:16AM |
Re: CoreXY printer, print slowly shifts / leans to the right December 12, 2019 07:37AM |
Re: CoreXY printer, print slowly shifts / leans to the right December 12, 2019 07:54AM |
Admin Registered: 13 years ago Posts: 3,096 |
Re: CoreXY printer, print slowly shifts / leans to the right December 12, 2019 09:17AM |
Re: CoreXY printer, print slowly shifts / leans to the right December 12, 2019 10:15AM |
Re: CoreXY printer, print slowly shifts / leans to the right December 12, 2019 12:45PM |
Re: CoreXY printer, print slowly shifts / leans to the right December 12, 2019 02:01PM |
, maar mijn motoren zitten niet met stekkers want die zaten er niet op, dus een kant en klare TL smoother aansluiten kan toch niet.|
Re: CoreXY printer, print slowly shifts / leans to the right December 12, 2019 03:41PM |
Re: CoreXY printer, print slowly shifts / leans to the right December 12, 2019 04:04PM |
Re: CoreXY printer, print slowly shifts / leans to the right December 15, 2019 11:16AM |
Re: CoreXY printer, print slowly shifts / leans to the right December 15, 2019 01:18PM |
Re: CoreXY printer, print slowly shifts / leans to the right December 15, 2019 01:45PM |
Re: CoreXY printer, print slowly shifts / leans to the right December 15, 2019 06:18PM |
Re: CoreXY printer, print slowly shifts / leans to the right December 16, 2019 01:22AM |
Re: CoreXY printer, print slowly shifts / leans to the right December 16, 2019 02:09AM |
Re: CoreXY printer, print slowly shifts / leans to the right December 16, 2019 03:44AM |
Admin Registered: 15 years ago Posts: 7,341 |
Re: CoreXY printer, print slowly shifts / leans to the right December 16, 2019 04:18AM |
Re: CoreXY printer, print slowly shifts / leans to the right December 16, 2019 05:55AM |
Re: CoreXY printer, print slowly shifts / leans to the right December 16, 2019 06:30AM |
Re: CoreXY printer, print slowly shifts / leans to the right December 16, 2019 06:53AM |
Re: CoreXY printer, print slowly shifts / leans to the right December 16, 2019 12:46PM |
Re: CoreXY printer, print slowly shifts / leans to the right December 16, 2019 01:35PM |
HugoW
I consider buying a real smoothieboard which supposedly is the best there is, or go Homarinus' way, or somewhere in between.
Re: CoreXY printer, print slowly shifts / leans to the right December 16, 2019 02:38PM |
Re: CoreXY printer, print slowly shifts / leans to the right December 16, 2019 03:22PM |
dc42
HugoW
I'm biased (see my signature); but Duet 3 is light years ahead of any Smoothieboard you can get right now (and way overkill for typical 3D printer applications). Even the 3-year old Duet WiFi and Duet Ethernet are better than current Smoothieboards in almost every respect. Smoothieboard 2 is still in kickstarter - maybe Duet will have some proper competition when it's released.
I still think your issue is caused by insufficient direction-to-step setup or hold time, which should be fixable in firmware. The datasheet gives the minimum values as 650ns.
Re: CoreXY printer, print slowly shifts / leans to the right December 17, 2019 06:19AM |
