Streaks before / after holes etc... January 16, 2020 10:53AM |
Re: Streaks before / after holes etc... January 16, 2020 11:21AM |
Re: Streaks before / after holes etc... January 16, 2020 12:25PM |
Re: Streaks before / after holes etc... January 16, 2020 01:54PM |
EEOVERKILL
The streaks im referring to are as wide as the holes. The raised line looks to be some squeeze out yes. The streaks are shallower than the other areas. Thats what im wondering about. It's not just inside the print.
Re: Streaks before / after holes etc... January 16, 2020 02:28PM |
Re: Streaks before / after holes etc... January 16, 2020 04:05PM |
Re: Streaks before / after holes etc... January 16, 2020 06:07PM |
Use a ruler to measure how far a line on your filament moves for 10mm or 20mm of extrusion and/or retraction. That will get you close, it isn't super precise, but it gets you close. Then do test prints, fiddle with the extrusion modifier and use that as the model to tweak in the extruder steps. Making your extrusion modifier less than 1 will increase the gaps between lines I would guess, try making it >1.Quote
EEOVERKILL
Ahhhh I'm still tweaking. Im getting closer. I dialed down the esteps to 92 from the default 96. The older version of marlin I was using had a default of 92.6. I have the extrusion multiplier at 0.8. The lines are thin so I going to bring the multiplier back to 1 and see what happens.
Re: Streaks before / after holes etc... January 16, 2020 11:11PM |
Re: Streaks before / after holes etc... January 17, 2020 06:22AM |
Re: Streaks before / after holes etc... January 17, 2020 07:27AM |
Re: Streaks before / after holes etc... January 17, 2020 07:29AM |
Re: Streaks before / after holes etc... January 17, 2020 09:03AM |
CVRIV
I only having this issue when I'm printing holes etc though. Can't be a mechanical issue.
Re: Streaks before / after holes etc... January 17, 2020 10:15AM |
the_digital_dentist
CVRIV
Try cutting one of those prints across the streak and measure the thickness of the streak and the rest of the print. Look at it edge-on under a microscope.
The truth hurts because the truth is all there is...
Re: Streaks before / after holes etc... January 17, 2020 11:15AM |
Re: Streaks before / after holes etc... January 17, 2020 11:30AM |
You must have printed a lot of parts to take 10 hours, those two don't look like more than about 3... There is a lesson, do test prints before big lots.Quote
CVRIV
Oh god. I'm so upset. 10 hours of printing and the parts are severely warped. I can't use these. What a waste. I have my print bed set to 65. Do you think I should raise the temp or just use PVA glue to fix this problem?
I need to modify these parts to be thinner.
Re: Streaks before / after holes etc... January 17, 2020 11:53AM |
dlc60
What are you printing? Warps mean you aren't getting the first layer stuck. Your pics don't look like ABS, but when I print ABS I usually put mouse ears on a square corners if I have problems. When I design parts, I avoid sharp corners...Quote
CVRIV
DLC
Re: Streaks before / after holes etc... January 17, 2020 12:06PM |
EEOVERKILL
dlc60
CVRIV
DLC
I'm going to try again. I was seriously under-extruding and was compensating. I tweaked the esteps until I got the 100mm I was expecting. My esteps is 97. I was printing at 90. I'm very nearly sure I have to adjust my z probe offset again.
We'll see what happens once I get all this done. I bought some glue sticks just in case. Oh I'm printing with PLA. My parts were 7mm thick with solid infill, I wonder how much that contributes to warping.
Re: Streaks before / after holes etc... January 17, 2020 01:24PM |
Re: Streaks before / after holes etc... January 17, 2020 01:30PM |
dlc60
EEOVERKILL
dlc60
CVRIV
DLC
Ok. Thats going to be my next thing to knock out. Thanks.
Solid infill? That is a problem. The more infill you have, the more likely the part is to warp and pull off the bed. Methods and opinions differ, but when I am making structural parts, I do not go over 50% infill and I use 3-4 walls for strength. Most of the time I infill at 30-35%, With Simplify3D I use full honeycomb, with CURA I like cubic subdivision pattern. Pick a sweet spot in your temperature for a filament. For fun stuff, toys and ornaments I will usually lean to the cooler side of the PLA temperature range. For a structural part (PETG or ABS) I pick about the middle because I care more about layer adhesion than prettiness.
DLC
Re: Streaks before / after holes etc... January 24, 2020 09:03PM |
Re: Streaks before / after holes etc... January 24, 2020 11:10PM |
Re: Streaks before / after holes etc... January 25, 2020 03:30PM |
Re: Streaks before / after holes etc... January 25, 2020 04:01PM |
