Large PETG part warping (even if same design is printed in PLA) February 02, 2020 03:10AM |
Re: Large PETG part warping (even if same design is printed in PLA) February 02, 2020 06:14AM |
Admin Registered: 11 years ago Posts: 3,096 |
Re: Large PETG part warping (even if same design is printed in PLA) February 02, 2020 01:56PM |
Ohmarinus
Did you try rotating the part so that it sits differently on the bed? And do you print with a print cooling fan? How about turning it off for the first few layers? You can also try printing with a slightly lower temperature or raising the temp on your heated bed just to try out if that works.
Would it be possible to make the brim 3 layers high instead of one layer?
So many options...
Re: Large PETG part warping (even if same design is printed in PLA) February 02, 2020 04:49PM |
Re: Large PETG part warping (even if same design is printed in PLA) February 03, 2020 08:56AM |
Re: Large PETG part warping (even if same design is printed in PLA) February 03, 2020 02:55PM |
Re: Large PETG part warping (even if same design is printed in PLA) February 04, 2020 05:51PM |
Re: Large PETG part warping (even if same design is printed in PLA) February 11, 2020 09:29AM |
Re: Large PETG part warping (even if same design is printed in PLA) February 12, 2020 04:53AM |
Re: Large PETG part warping (even if same design is printed in PLA) February 12, 2020 07:14PM |
Ohmarinus
Maybe as a last resort you could design a 2x layer height circle on the spot where it lifts. Like a manual brim? Make sure the circle has a diameter of at least 3cm. Worth a try. I had to do some of these manual attachments one time for a print when I was making a spool holder back in 2012. From there on I just decided to not print spool holders anymore (but the print worked!).
Re: Large PETG part warping (even if same design is printed in PLA) February 12, 2020 10:54PM |
Re: Large PETG part warping (even if same design is printed in PLA) February 16, 2020 01:54PM |
rq3
For what it's worth, I print PETG at 230 C, with a bed temp of 40 C, at between 40 and 240 mm per second. Glass bed with Elmers school glue for adhesion, with the part cooling fan at full speed at all times, for all layers. If the print starts with no part cooling, it does not stick, or warps badly.
Just my experience.
Re: Large PETG part warping (even if same design is printed in PLA) April 27, 2020 11:08AM |
