Nozzle blobbing March 28, 2020 10:13AM |
Re: Nozzle blobbing March 29, 2020 06:44PM |
Re: Nozzle blobbing March 29, 2020 08:11PM |
rq3
What filament? Hatchbox makes many different filaments. PLA, PETG? In either case, I think your nozzle temperature is very low. I use about 210C for PLA, and 230C for PETG. There's no way your nozzle is at 180F (82C). If it's at 180C (356F) it's still way too low for either of these materials.
Re: Nozzle blobbing April 27, 2020 11:17AM |
Re: Nozzle blobbing April 27, 2020 03:40PM |
Wissing
Try cleaning any plastic from in between the teeth of the hobbed bolt on your extruder (or whatever you have gripping the filament to push it down through the extruder). Maybe you tried this, but it's the kind of thing that can slowly get worse over time.
Like you said, if you've been printing fine for over a year, then it's probably not a matter of changing settings. Unfortunately, changing settings is one of the easiest things to do, so we all jump straight to that. But it can be a lot of confusion for nothing. It's probably related to some kind of mechanical wear or buildup.
