Slight Z Banding / Ribbing April 15, 2020 04:00PM |
Re: Slight Z Banding / Ribbing April 17, 2020 09:31AM |
Re: Slight Z Banding / Ribbing April 18, 2020 01:22PM |
Re: Slight Z Banding / Ribbing April 18, 2020 03:54PM |
Re: Slight Z Banding / Ribbing April 20, 2020 04:36PM |
MCcarman
OK.
Im thinking this is an issue of binding/over constraining. Since you have a spiral coupler the resistance may cause the spiral to wind up/down instead of the platform moving the complete distance.
MCcarman
Is the thrust bearing just resting on the mounting?
MCcarman
Whats holding the motor in place? In theory you only need to stop it rotating not constrain its position.
MCcarman
I would make one guide rod the position control so constrain it top and bottom and the other in a slot left/right in picture so it can always be the same distance from the other.
Wondering if the lead screw is not parallel to the guide rods. Since it looks very constrained. If it makes the thrust bearing (or the housing) not sit perpendicular then it may alter the z height as it rotates.
You could try slackening the fixings holding the nut to the bed carriage so the nut can float to an unconstrained position. It will be tensioned in Z by gravity. However if the fixings are just loose they may vibrate out so you may need to Loctite them in. For a test print you could just keep an eye on them.
Long day.
Hope this helps.
Re: Slight Z Banding / Ribbing May 03, 2020 11:15PM |
Re: Slight Z Banding / Ribbing June 05, 2020 01:03PM |
