ABS.. what needs adjusting? May 06, 2020 10:54PM |
Re: ABS.. what needs adjusting? May 07, 2020 07:51AM |
Re: ABS.. what needs adjusting? May 07, 2020 08:03AM |
Re: ABS.. what needs adjusting? May 07, 2020 08:43AM |
Re: ABS.. what needs adjusting? May 07, 2020 08:50AM |
Re: ABS.. what needs adjusting? May 07, 2020 11:14AM |
Re: ABS.. what needs adjusting? May 07, 2020 11:30AM |
Re: ABS.. what needs adjusting? May 08, 2020 05:18PM |
Re: ABS.. what needs adjusting? May 08, 2020 05:42PM |
Re: ABS.. what needs adjusting? May 08, 2020 06:07PM |
Re: ABS.. what needs adjusting? May 09, 2020 07:17AM |
Re: ABS.. what needs adjusting? May 09, 2020 10:54AM |
Re: ABS.. what needs adjusting? May 09, 2020 11:03AM |
Re: ABS.. what needs adjusting? May 09, 2020 02:43PM |
Re: ABS.. what needs adjusting? May 09, 2020 03:08PM |
Re: ABS.. what needs adjusting? May 09, 2020 04:00PM |
Re: ABS.. what needs adjusting? May 10, 2020 11:18AM |
Re: ABS.. what needs adjusting? May 10, 2020 01:06PM |
Re: ABS.. what needs adjusting? May 10, 2020 02:32PM |
Re: ABS.. what needs adjusting? May 11, 2020 07:49AM |
Re: ABS.. what needs adjusting? May 11, 2020 09:24AM |
MCcarman
Makes more sense now as i can see you have characters in the bottom layer.
Left one is best. Shows more squish on 1st layer. However the perimeters don't look joined so i think you may be under extruding.
Check extruder calibration and extrusion width settings.
Set 1st layer extrusion multiplier to about 130% to get good squish and compensate for nozzle height variability.
Looks like you have different infill directions set for 1st layer and general. Don't know why you don't have solid infill above the letters. May be the general under extrusion issue. That's why when you look through the letters the filaments running vertically have spaces between them.
Re: ABS.. what needs adjusting? May 11, 2020 07:14PM |
Re: ABS.. what needs adjusting? May 14, 2020 11:33PM |
Re: ABS.. what needs adjusting? June 13, 2020 11:03PM |
