I have a frustrating problem.
When I now try to autohome, autohoming does not go to the center of the build plate. It tests the X enstop twice as before, but now it only touches the Y endstop once and then there is no movement on the Y axis after that.
It then only prints along the front edge of the build plate where it had stopped after triggering the Y endstop the once.
I can move the build plate with move axis command, even after it has touched the Y endstop, so all movement is working.
The only giveaway is that when it tried to autohome it touches the X axis twice (retest) before moving to the center. Y axis touches the endstop only once (no retest) then does not move to the center as it should.
I have no more hair left to pull out... Please help.
Was working fine and suddently, after a code update of Marlin was updated to board, this... I can't find the culprit in any cahnges that were made.
I have Marlin 1.1.9 on a MKS Gen L Reprap board but built it as 400x400x400.
I hope you are safe and well?
Mark
