YMIN
June 14, 2020 05:18AM
I have a *lcd2004
MKS-gen-L-v1.0
3D touch
Fillament runout sensor*
I run the marlin firmware 2.0.5.x on a *RepRap Discount Smart Controller* and *MKS_GEN_L motherboard*.
Everything works fine but for the mechanical y-min switch: it stays triggered.
(m119) YMIN work under 1.1.2 ao everything is connect right and is physicly working.
I don't know what to do... Does maybe someone have an idea of what I can do?
Flsun
These are my files:
pins_RAMS.h
configuration.h
configuration_adv.h
Edited 4 time(s). Last edit at 06/14/2020 02:42PM by edensan.
Re: YMIN
June 14, 2020 07:33AM
there are a few posts about this. Maybe something is wrong with the pins file. Try using Y-Max pin. Others have done that. with success.
Re: YMIN
June 14, 2020 07:44AM
Im not that experianced can and wil you explaine how i do this?
Thx in advance
Edited 1 time(s). Last edit at 06/14/2020 08:15AM by edensan.
Re: YMIN
June 14, 2020 11:46AM
i changed pins 14 to 15 and 15 to 14 no difference thx to PomAdam in this tread
Edited 1 time(s). Last edit at 06/14/2020 11:57AM by edensan.
Re: YMIN
June 14, 2020 03:58PM
i did put back a (working} backup and also no endstop and inverted y! confused smiley HELP!!!!!
Re: YMIN
June 14, 2020 04:07PM
move your endstop connector to YMAX port and change the config to use Ymax for the Y endstop.
I have not done this. Just reading from posts on Marlin Git Issues
[github.com]
[github.com]
check them out
Re: YMIN
June 14, 2020 05:03PM
verry strange i put the plug in the ymax and its working!!
Re: YMIN
June 14, 2020 06:30PM
Yeah, sounds like something is wrong with the pins file.
You can probably fix it if you wanted but Marlin should do it.
Re: YMIN
June 15, 2020 06:15AM
Bye the way.
Don't run the Bowden as shown in the picture. Don't tie wrap to the cable near the hot end - it creates a horrible bend in the tube and doesn't feed smoothly into the hot end.
Not sure how they managed to get the cable deflected that much - i assume they clamped the cable just for the photo but it wont work when you try to level the bed.
