Gaps in prints and printed object is not strong(breaking)
Posted by bentech4u
August 03, 2020 06:11AM
HI
i was creating a new printer(prusa model). print quality is good and no lines in prints. but i can able to see small gaps in every print.
If i print big models, which is breaking while removing support itself.
i am attaching some pictures referring to my issue
silver/gray color is acccreate PLA
Green one is Sunlu china
Yellow one is Sunlu china
open | download - screenshot_769.png (891.7 KB)
open | download - screenshot_768.png (656.1 KB)
open | download - screenshot_767.png (824.9 KB)
open | download - screenshot_766.png (880.7 KB)
open | download - screenshot_765.png (854.2 KB)
VDX
Re: Gaps in prints and printed object is not strong(breaking)
August 03, 2020 06:44AM
... slightly higher temp will fuse better ... but there are some tiny "zickzack-waves" visible too in the layers, what could be caused by extruder variations (too much extrudate or too slow) ...
Viktor
August 03, 2020 07:12AM
you mean to say extruder calibration also required ?
August 03, 2020 07:36AM
Do you hear any pops coming from the nozzle during printing by any chance?
http://www.marinusdebeer.nl/
August 03, 2020 02:01PM
hi heard some, i thought it's skipping steps or extruder. or the filament is slipping . after that i reset extruder, tightened tension springs, still same,...
haring some time, not very often
August 30, 2020 05:58PM
What kind of stepper drivers are you using? What is your extruder stepper driver's VREF? What kind of hot end are you using? What kind of extruder are you using?
August 31, 2020 12:41AM
HI
my board is MKS-BASE v1.4, which uses 4982 as a motor driver. and my extruder is mk8 extruder(direct drive)
VREF, i didn't measured yet
August 31, 2020 02:03AM
I haven't used 4982 drivers before, but with 4988 drivers, which may be similar, I have to set VREF so 750mV to get the clicking to stop. Using an E3D v6 hot end below my MK8 extruder in a direct drive configuration works well.
If you still experience clicking, I'd recommend going with a geared extruder such as the Titan or Greg's Wade's one.
The gaps occur when the nozzle loses pressure, such as when a step is lost and clicking is heard.
September 15, 2020 02:26PM
HI
i just checked VREF and it is 850mV. also i have ordered Titan
as you said, 4982 and 4988 drivers are similar,
