Printing ABS in a closed box failing August 21, 2020 09:12AM |
Admin Registered: 11 years ago Posts: 3,096 |
Re: Printing ABS in a closed box failing August 21, 2020 10:21AM |
Re: Printing ABS in a closed box failing August 21, 2020 01:54PM |
the_digital_dentist
I think that the main problem is pretty obvious. The object being printed is very small. That means the layer time is small, which means the plastic from previous layer hasn't cooled and solidified before the nozzle comes back and dumps more molten plastic on the print. Try printing 3 or 4 objects separated on the bed to allow more time for the plastic to cool and solidify, or print a larger object. Turn on print cooling, but not the fan - use the layer time adjustment and set it for a minimum layer time of 30 seconds or so. The slicer will adjust the print speed to take at least 30 sec per layer which should improve things.
This is one of the things that people who want to print super fast usually fail to consider. What good does it do to print at 300 mm/sec if after every layer you have to stop and wait for the print to cool enough that you can print the next layer?
Another problem- never print with the line width set narrower than the nozzle diameter. If the line width is actually narrower than the nozzle, where is the extruded plastic going to end up? It will wander back and forth and print quality will suffer. If you are over extruding, correct the extrusion, not the line width. If you set the line width to 0.4 mm and extrusion to 100%, you should get a 0.4 mm wide line. If you're getting a wider or narrower line, recalibrate. If your controller's firmware has pressure advance and nonlinear extrusion, use them.
That 20 mm "calibration" cube is worse than useless because of all the problems it creates for printing noobs. When you calibrate, use the largest object you can measure accurately. If you have a 250mm caliper, print a square or rectangle that is 175 mm on a side and if you have a 150 mm caliper, print a 100 mm square, then measure the sides and the diagonals. Use the side dimensions to do your XY calibration and use the diagonal measures to check squareness of the X and Y axes (the diagonals will be the same length if the axes are square). Any measurement you make will include some error. If you calibrate using a 20 mm cube, when you print objects larger than 20 mm the error will get multiplied. If you calibrate using a large object, when you print smaller objects the error will get divided. The % error will remain constant, but in the real world, it's the absolute error, not the percent error that matters.
Re: Printing ABS in a closed box failing August 21, 2020 05:29PM |
Re: Printing ABS in a closed box failing August 22, 2020 01:22PM |
Re: Printing ABS in a closed box failing August 22, 2020 04:38PM |
Re: Printing ABS in a closed box failing August 22, 2020 04:42PM |
Admin Registered: 16 years ago Posts: 13,874 |
Re: Printing ABS in a closed box failing August 23, 2020 10:35AM |
Re: Printing ABS in a closed box failing August 23, 2020 11:09AM |
Re: Printing ABS in a closed box failing August 23, 2020 12:29PM |
Re: Printing ABS in a closed box failing August 23, 2020 06:35PM |
the_digital_dentist
Your vapor smoothing looks like it's softening the bulk of the print. 5 minutes seems like a long time.
In the rare event that I vapor smooth prints, I heat the acetone to about 100C in a big pot with a cover, then lower the print into the vapor for a few seconds- just long enough for the vapor to condense on the print surface, never more than 5 seconds, then pull it back out and replace the cover on the pot. I let the print sit for a couple minutes for the acetone to evaporate and then dip the print in the vapor again. It usually only takes 2 or 3 dip and dry cycles to get a nice glossy finish. Handle the print and hang it from a wire so you don't end up with fingerprints in the surface.
Why are you polishing this piece?
Re: Printing ABS in a closed box failing August 31, 2020 10:28AM |
Re: Printing ABS in a closed box failing August 31, 2020 12:17PM |
Re: Printing ABS in a closed box failing August 31, 2020 02:30PM |
Re: Printing ABS in a closed box failing September 01, 2020 05:28AM |
Re: Printing ABS in a closed box failing September 01, 2020 07:49AM |
Ohmarinus
a Mandalorian model that is 7cm tall (pretty small) with before and after vapor smoothing:
Re: Printing ABS in a closed box failing September 01, 2020 09:01AM |
Roberts_Clif
Ohmarinus
This is what I need to learn more about vapor smoothing, I have read a few posts, articles on vapor smoothing just do not have an area to safely setup.
Sample Video
When vapor smoothing is there a layer height that works best or is it ok to 3D Print as say .15mm - .28mm layer heights.
Re: Printing ABS in a closed box failing September 01, 2020 05:41PM |
Ohmarinus
From what I understand there are two methods:
Cold vaporsmoothing
Warm vaporsmoothing
When using heat, the acetone in the air seems to work much faster, when doing the cold method the acetone seems to be less aggressive. I prefer the cold option.
Beyond that I have no clue, just trying out different options. I just set the layer height to what correlates best to my nozzle size and model dimensions. 0.2 is the best height in my personal experience. Also no division errors when divided by degrees/revolution of the Z-axis stepper. When smoothing I rather do it too short than too long. The only drawback of cold vaporsmoothing is that I notice the bottom area gets smoothed more than the top area of the model, that's why I have to turn it around every time. When using heat, the vapor is more equally distributed throughout the vessel.
Re: Printing ABS in a closed box failing September 05, 2020 03:13PM |
Re: Printing ABS in a closed box failing September 06, 2020 05:36AM |
the_digital_dentist
Re: Printing ABS in a closed box failing September 06, 2020 09:02AM |
Admin Registered: 17 years ago Posts: 7,879 |
Ohmarinus
Sooooo meanwhile I've gotten to the point where a better sacrificial tower has improved the print quality drastically. Layer minimal time didn't work wonders because somehow Cura doesn't add in a retract when moving the nozzle away and it only moves the head 2cm away so it still keeps radiating heat onto the piece.
Re: Printing ABS in a closed box failing September 09, 2020 02:50AM |
Re: Printing ABS in a closed box failing May 11, 2021 02:10AM |
I do like those hands, they look amazing!Quote
Ohmarinus
the_digital_dentist
I'm just curious how parts will come out, this piece wasn't printed right (hence the melty look, it was like this before smoothing) so I decided to try it out. I have been working on this machine to specifically be able to print ABS models and smooth them so I can offer ABS as a material to my students at the art academy. The printers on the art academy only print in PLA and while it's a great material, it doesn't always have the properties one might need for a project. Whether that be vapor smoothing to somewhat hide the printed quality (muy importante in artworks) or having plastic models that withstand some heat. So I'm now running one machine geared towards PLA, another one that runs PETG and a third with ABS. The PLA and PETG machines can both run PLA and PETG though. I just don't like to switch filaments a lot and I had the machines anyway.
I did a lot of vapor smoothing in the meantime and have discovered that indeed heating it up will speed up and improve the process. When using cold vapor, the vapor tends to sit on the bottom of the vessel. What I tried out so far was to heat the glass vessel under hot tap water to around 40/50ºC and inject acetone with a needle onto paper kitchen towel that is secured around the wall of the glass vessel. The hot glass will evaporate the acetone and circulate is through the vessel so it gets everywhere. Then I leave the part in for max 2 minutes (I think this may actually already be too long) and then take it out. Usually have to do 2 or 3 passes, but this smooths out the part top and bottom and also in small crevices.
Cold vapor smoothing doesn't get into the holes of the part so it really isn't the best way. It is great for simple parts, but I realize now that heat will improve the quality drastically and also preserve more detail because it doesn't go as deep, but the surface that gets smoothed out really is smoothed nicely. On top of that, it seems the acetone dissolves out of the model faster as well.
Fan duct smoothed out so there's less noise:
Just a test to see if it's ok:
