Hello everyone,
I have registered here 1. because I am an enthusiastic tinkerer and 2. because I despair of my new Delta printer (Tevo Little Monster).
I bought a used Tevo Little Monster. Unfortunately it had some problems, badly assembled (screws twisted and crooked) the hotend is permanently clogged etc.
Most of the problems I have solved now and actually it would be ready for printing. But unfortunately I can't calibrate the printing bed.
As you can see on the pictures, some of the spots on the printing bed are much too close and some are much too far away.
The printer runs with smoothieware.
The following things I have tried so far:
-Printer frame completely disassembled, reassembled with a right angle and measured with a digital spirit level (if I can trust the spirit level, the frame is assembled to an accuracy of 0.05°)
-I set the small pins for the optical endstops to an accuracy of 0.05 mm.
-I tried to do the delta calibration with G32 first and then the mesh calibration with G31. But I have the feeling that it doesn't make a difference if I do the mesh calibration or not, I have exactly the same result.
-I have done the "Least squares (David Crocker variant)" with a different firmware.
So far nothing has worked and the result is always the same. Unfortunately I could not measure the arms yet, because there are several screws broken and I only want to drill them out when I have the right spare screws.
I suspect the firmware or the arms, but I am not sure and ask here for advice not to waste more money.
Do any of you have an idea where this error could trigger the image?
Before printing the image I did a least squares delta clearing and a mesh calibration. But the result is exactly the same with a normal delta calibration and without mesh calibration.
The following steps I plan to take to correct the error, but I am afraid to be on the wrong track.
-I want to exchange the mainboard for a Duet Wifi to exclude the firmware.
-I want to exchange the Effector with a Duet Smart Effector to use MagBallArms and have the sensor directly on the nozzle.
-I want to make the bed manually adjustable with springs. But I have little hope for success.
-I would like to install MagBallArm from Haydn Huntley.
If someone has an idea or knows this problem I would be very grateful.
