Bottom layers do not want to adhere to vase mode walls? October 18, 2020 08:42AM |
Admin Registered: 13 years ago Posts: 3,096 |
Re: Bottom layers do not want to adhere to vase mode walls? October 18, 2020 10:41AM |
Re: Bottom layers do not want to adhere to vase mode walls? October 18, 2020 11:55AM |
Roberts_Clif
Calibrating the newer versions Cura is one reason I still use the Older Cura version 15.04.6, after over three years adjusting the many setting of Cura finally working more with newer versions. Though still mostly 3D Print using the 15.04.6 as it has worked so well for me. An recently found that Creality Slicer 1.2.3 works with Cura 15.04.6 profiles.
Do not know the advantages / disadvantages of using Cura 15.04.6 vs Creality Slicer 1.2.3 though over the next few months will try to find some.
What nozzle are you using an layer height, noticed the spacing both vertical and horizontal.
I have two Prusa i3 style clones they are Hictop 3DP11 / 3DP12.
Re: Bottom layers do not want to adhere to vase mode walls? October 18, 2020 12:49PM |
Re: Bottom layers do not want to adhere to vase mode walls? October 18, 2020 05:43PM |
Roberts_Clif
Then could it be quite possible that the Vase with detached bottom model may be in need repair...
Re: Bottom layers do not want to adhere to vase mode walls? October 18, 2020 09:56PM |
Re: Bottom layers do not want to adhere to vase mode walls? October 19, 2020 02:22AM |
Roberts_Clif
It appears that the Vase model is a solid is it 3D Printed using Spiralize Outer Contour
since the spiralize outer contour is a sure way to get no vertical seams.|
Re: Bottom layers do not want to adhere to vase mode walls? October 19, 2020 08:18AM |
Re: Bottom layers do not want to adhere to vase mode walls? October 19, 2020 09:52AM |
Ohmarinus
Roberts_Clif
Yep, it is printed with that optionsince the spiralize outer contour is a sure way to get no vertical seams.
Re: Bottom layers do not want to adhere to vase mode walls? October 19, 2020 01:01PM |
Roberts_Clif
Ohmarinus
Roberts_Clif
Have you tried to print with multiple outer shell walls using infill prints after perimeters.
I'll try something right now with a new print.|
Re: Bottom layers do not want to adhere to vase mode walls? October 20, 2020 11:51AM |
Re: Bottom layers do not want to adhere to vase mode walls? October 21, 2020 01:28PM |
