Z probe 0 not found
Posted by TZTZ
Z probe 0 not found
November 29, 2020 12:40PM
Hey, it would be nice if someone could help me solve this problem where when i try to run calibration gcode i get Z probe 0 not found
when i run it i get the following:
11/29/2020, 6:29:52 PM 	G32
Error: in file macro line 8: G30: Z probe 0 not found
Error: in file macro line 9: G30: Z probe 0 not found
Error: in file macro line 10: G30: Z probe 0 not found
Error: in file macro line 11: G30: Z probe 0 not found
Error: in file macro line 12: G30: Z probe 0 not found
Error: in file macro line 13: G30: Z probe 0 not found
Error: in file macro line 14: G30: Z probe 0 not found
11/29/2020, 6:29:48 PM 	G29
Error: G29: Z probe 0 not found
my config.g is:
; Configuration file for Duet WiFi (firmware version 3)
; executed by the firmware on start-up
; generated by RepRapFirmware Configuration Tool v3.1.9 on Sun Nov 29 2020 17:36:43 GMT+0100 (Central European Standard Time)
; General preferences
G90                                            ; send absolute coordinates...
M83                                            ; ...but relative extruder moves
M550 P"3D Printer"                             ; set printer name
M665 R268 L420 B10 H599                        ; Set delta radius, diagonal rod length, printable radius and homed height
M666 X0 Y0 Z0                                  ; put your endstop adjustments here, or let auto calibration find them
; Network
M552 S1                                        ; enable network
M586 P0 S1                                     ; enable HTTP
M586 P1 S0                                     ; disable FTP
M586 P2 S0                                     ; disable Telnet
; Drives
M569 P0 S1                                     ; physical drive 0 goes forwards
M569 P1 S1                                     ; physical drive 1 goes forwards
M569 P2 S1                                     ; physical drive 2 goes forwards
M569 P3 S0                                     ; physical drive 3 goes backwards
M584 X0 Y1 Z2 E3                               ; set drive mapping
M350 X16 Y16 Z16 E16 I1                        ; configure microstepping with interpolation
M92 X80.00 Y80.00 Z80.00 E84.88                ; set steps per mm
M566 X1200.00 Y1200.00 Z1200.00 E1200.00       ; set maximum instantaneous speed changes (mm/min)
M203 X18000.00 Y18000.00 Z18000.00 E1200.00    ; set maximum speeds (mm/min)
M201 X1000.00 Y1000.00 Z1000.00 E1000.00       ; set accelerations (mm/s^2)
M906 X1000 Y1000 Z1000 E1400 I30               ; set motor currents (mA) and motor idle factor in per cent
M84 S30                                        ; Set idle timeout
; Axis Limits
M208 Z0 S1                                     ; set minimum Z
; Endstops
M574 X2 S1 P"!xstop"                           ; configure active-high endstop for high end on X via pin !xstop
M574 Y2 S1 P"!ystop"                           ; configure active-high endstop for high end on Y via pin !ystop
M574 Z2 S1 P"!zstop"                           ; configure active-high endstop for high end on Z via pin !zstop
; Z-Probe
M558 P4 C"^e1temp" H5 F120 T6000               ; set Z probe type to switch and the dive height + speeds
G31 P500 X0 Y0 Z0.5                            ; set Z probe trigger value, offset and trigger height
M557 R85 S20                                   ; define mesh grid
; Heaters
M308 S0 P"bedtemp" Y"thermistor" T100000 B4138 ; configure sensor 0 as thermistor on pin bedtemp
M950 H0 C"bedheat" T0                          ; create bed heater output on bedheat and map it to sensor 0
M307 H0 B1 S1.00                               ; enable bang-bang mode for the bed heater and set PWM limit
M140 H0                                        ; map heated bed to heater 0
M143 H0 S120                                   ; set temperature limit for heater 0 to 120C
M308 S1 P"e0temp" Y"thermistor" T100000 B4138  ; configure sensor 1 as thermistor on pin e0temp
M950 H1 C"e0heat" T1                           ; create nozzle heater output on e0heat and map it to sensor 1
M307 H1 B0 S1.00                               ; disable bang-bang mode for heater  and set PWM limit
M143 H1 S280                                   ; set temperature limit for heater 1 to 280C
; Fans
M950 F0 C"fan0" Q500                           ; create fan 0 on pin fan0 and set its frequency
M106 P0 S0 H1 T45                              ; set fan 0 value. Thermostatic control is turned on
M950 F1 C"fan1" Q500                           ; create fan 1 on pin fan1 and set its frequency
M106 P1 S1 H1 T45                              ; set fan 1 value. Thermostatic control is turned on
M950 F2 C"fan2" Q500                           ; create fan 2 on pin fan2 and set its frequency
M106 P2 S1 H-1                                 ; set fan 2 value. Thermostatic control is turned off
; Tools
M563 P0 D0 H1 F0:2                             ; define tool 0
G10 P0 X0 Y0 Z0                                ; set tool 0 axis offsets
G10 P0 R0 S0                                   ; set initial tool 0 active and standby temperatures to 0C
; Custom settings are not defined
my bed.g is:
; bed.g
; called to perform automatic delta calibration via G32
M561 ; clear any bed transform
; Probe the bed at 3 peripheral and 3 halfway points, and perform 6-factor auto compensation
; Before running this, you should have set up your Z-probe trigger height to suit your build, in the G31 command in config.g.
G30 P0 X0 Y89.9 H0 Z-99999
G30 P1 X77.86 Y-44.95 H0 Z-99999
G30 P2 X-77.86 Y-44.95 H0 Z-99999
G30 P3 X0 Y44.9 H0 Z-99999
G30 P4 X38.88 Y-22.45 H0 Z-99999
G30 P5 X-38.88 Y-22.45 H0 Z-99999
G30 P6 X0 Y0 H0 Z-99999 S6
; Use S-1 for measurements only, without calculations. Use S4 for endstop heights and Z-height only. Use S6 for full 6 factors
; If your Z probe has significantly different trigger heights depending on XY position, adjust the H parameters in the G30 commands accordingly. The value of each H parameter should be (trigger height at that XY position) - (trigger height at centre of bed)
