Extruder temp drops while printing December 15, 2020 06:49AM |
Re: Extruder temp drops while printing December 15, 2020 02:30PM |
Re: Extruder temp drops while printing December 15, 2020 05:39PM |
frankvdh
Do you have a part cooling fan that is perhaps blowing on the nozzle or heater block?
What happens if you pause the print? Does the temperature rise again?
Another thought (although you seem to have already covered it) is that there's a bad connection somewhere in the heater wiring, so there is intermittent power supply to the heater as the hotend moves around. Can you put an LED in parallel with the heater element so you can see when it is actually getting power?
Re: Extruder temp drops while printing December 16, 2020 03:53PM |
Re: Extruder temp drops while printing December 16, 2020 05:47PM |
Re: Extruder temp drops while printing December 16, 2020 07:27PM |
