Look for the best information
Posted by Roberts_Clif
December 15, 2020 11:57AM
I am looking for information on the best way to slice and print this model
Thank you
Edited 1 time(s). Last edit at 12/15/2020 11:59AM by Roberts_Clif.
Re: Look for the best information
December 15, 2020 03:38PM
There are far too many practically unprintable objects out there. (It used to be same with programming... every high school kid and lab technician and salesman would create programs that *almost* worked, but were so fundamentally flawed and impenetrable that they were never going to ever work). So, as a general rule, I never print something if the designer doesn't have a photo of the actual printed result. Otherwise you are effectively testing and debugging his design. Unless it's a particularly good design, it is probably easier to design it yourself.
Apologies for the rant.
If you google, you can find many other models of Swamp Thing.
VDX
December 15, 2020 05:13PM
... you can try to separate/cut the figures into better managable chunks, print them and glue/assemble it aftermath ...
Viktor
December 15, 2020 05:37PM
frankvdh
You are only confirming what I already knew, I was inquiring for another user on another forum. I tried to find a simple way to 3D Print and could not.
VDX
And this is the only way that I came up with.
Thank You both.
