Nozzle repeatedly clogging while printing Ninjaflex TPU confused smiley
December 22, 2020 11:37AM
Hello,
I'm having a problem printing white NinjaFlex TPU on an Airwolf3D AXIOM Dual Direct Drive printer. I am trying to run some test prints of a face mask ear strap but am having problems with the nozzle clogging shortly after the print starts (within the first 5 or so minutes). What happens is the print will start printing the first layer without a problem, but after printing the brim and the outline of the part, the nozzle starts clogging as it prints the infill for the first layer. I used the recommended profile settings on the NinjaTek product page as a guide for the settings and am using Apex (Airwolf3D’s rebranded version of Cura) for the slicer with the standard TPU profile modified with the NinjaTek settings for speeds.
So far, I have tried a deep clean of the nozzle (which was using ABS previously), and tightening the hobbled bolt in the direct drive hoping that would help. I also tried changing the Z offset from the table in case the nozzle was too close or far away from the bed. I have attached an image showing the part I tried to print, and a copy of the profile I used for the test print (you can still view the settings without having Apex). Can anyone give me some advice on what I can do to solve this issue?
Thank you!
Jason O
open | download - Apex TPU Profile.ini (6.1 KB)
open | download - 20201216_103211.jpg (427.6 KB)
Re: Nozzle repeatedly clogging while printing Ninjaflex TPU confused smiley
December 22, 2020 02:21PM
Reduce the drive gear pressure for flexible filaments and try printing in relatively thick layers. print slowly- maybe 30-40 mm/sec. If you have a 0.4 mm nozzle, print in 0.25 or 0.3 mm layers. Print at the upper end of the recommended range for the filament, too.
December 23, 2020 03:18PM
the_digital_dentist
Thank you for the suggestions! Quick question, when you mentioned printing at the upper end of the recommended range for the filament, are you referring to speed, temperature, flow-rate, etc. (or all of the above)?
Thanks,
Jason O
December 23, 2020 03:34PM
Ooops. The upper end of the temperature range.
January 10, 2021 03:05PM
Make sure to turn off retraction and play with the speed.
My best results are on 15mm/sec but ultimately it depends on the extruder you have.
Edited 1 time(s). Last edit at 01/10/2021 03:05PM by whosrdaddy.
