Loosing reference after any layers January 17, 2021 08:56AM |
Re: Loosing reference after any layers January 17, 2021 09:08AM |
Re: Loosing reference after any layers January 17, 2021 09:51AM |
Roberts_Clif
This is a classic case of layer shifting.
Here is a list of a few causes.
1. smooth rod not clean and lubricated with a non-sticky lubricant.
2. linear bearing do not have a smooth min to max travel an are binding causing layer shifting.
3. stepper v-ref current not adjusted correctly allowing missed steps
Re: Loosing reference after any layers January 17, 2021 10:35AM |
Re: Loosing reference after any layers January 17, 2021 11:17AM |
Re: Loosing reference after any layers January 18, 2021 09:58AM |
the_digital_dentist
The shifting appears to be at a 45/135 degree angle. A corexy mechanism moves that way when one motor is not turning and the other is. I'd inspect motor cables and connectors and make sure the motor driver chips aren't overheating.
Re: Loosing reference after any layers January 18, 2021 11:39AM |
Re: Loosing reference after any layers March 01, 2021 12:01PM |
