Cura needs more filament than Repetier-Cura
Posted by Mj48
March 16, 2021 03:51PM
Now this might be a rather stupid question, but I'd be glad if someane can explain it. For quite some time I've been using Repetier(wich uses an old version of Cura Engine) as slicer. Due to the lack of some options, I started using the Cura GUI.
Now, what I don't understand is:
- In Repetier 0.6mm top/bottom thickness and 20% infill prints well
- In Cura 1mm top/bottom thickness and 20% infill results in a top surface that has gaps/holes
What is causing this? Is there any settings that I can change in Cura?
Thank you for your help
Edited 3 time(s). Last edit at 03/17/2021 01:14PM by Mj48.
