3D touch level sensor fix, turn it in a reliable and high accuracy sensor March 31, 2021 11:36AM |
Re: 3D touch level sensor fix, turn it in a reliable and high accuracy sensor April 01, 2021 04:30AM |
xpsion
a bed leveling sensor is one of key tools to achieve consistent printing efficiency.....
Re: 3D touch level sensor fix, turn it in a reliable and high accuracy sensor April 01, 2021 08:28AM |
Re: 3D touch level sensor fix, turn it in a reliable and high accuracy sensor April 01, 2021 10:48AM |
Re: 3D touch level sensor fix, turn it in a reliable and high accuracy sensor April 02, 2021 01:43AM |
leadinglights
MKSA seems to be unable to see that that lazy users not setting their printers up correctly is not the same thing as bed sensors not being useful tools. If I change a nozzle or build surface I will check the level and even the flatness with my sensor(s)
Mike
Re: 3D touch level sensor fix, turn it in a reliable and high accuracy sensor April 02, 2021 03:55AM |
MKSA
No, a properly built machine doesn't need it. .......
MKSA
I use ONE sensor integrated in the print head carriage to determine Z0 when the nozzle touches the bed, ......
Re: 3D touch level sensor fix, turn it in a reliable and high accuracy sensor April 02, 2021 10:37AM |
Re: 3D touch level sensor fix, turn it in a reliable and high accuracy sensor April 03, 2021 01:59PM |
leadinglights
Quote from 1st April
MKSA
Quote from 2nd April
MKSA
So was the first reply a case of "do what I say, not what I do", or was it an April Fools joke?
Mike
