Got this 3mm aluminum plate with Titan Aero head you see in pics below. Using Marlin with bilevel bed leveling and 9 measurement points. I'd just re-done the whole carriage and X ends to what you see below so that it does not stick out so much, is stiffer, and has the probe closer to the nozzle. Now, I can get the probe to all points the nozzle can go and it probes at very edges nicely.
My bed level test works better but darned thing still could be better. The test has been disturbed in pic below, I'd lifted it a bit and measured the thickness at various points. The thickness on the left side is pretty goot at 0.22 mm thickness. The right side though, it varies from 0.16 mm down to 0.1mm at the far edge.
The bed level matrix looks OK, looks like this:
echo: G29 W I0 J0 Z-0.37250
echo: G29 W I1 J0 Z-0.33250
echo: G29 W I2 J0 Z-0.46000
echo: G29 W I0 J1 Z0.01250
echo: G29 W I1 J1 Z0.01500
echo: G29 W I2 J1 Z-0.15000
echo: G29 W I0 J2 Z0.42250
echo: G29 W I1 J2 Z0.22000
echo: G29 W I2 J2 Z-0.24000
I'd seen somebody mention checking the twist in your two z-bars, that for me is quite good. I'd tried even offsetting that to see if there was an effect, I'd have to say that it isn't significant even if it were off.
Gonna try mechanical leveling some more to get the above matrix more flat but .. have done this before, and I'm expecting there will still be this 0.1mm difference over the bed. I'd like to see it under 0.05mm as I usually print with ABS and it is very particular about bed level.
Edited 1 time(s). Last edit at 05/16/2021 12:31PM by NovaHuta.
