core xy layers not aligned
Posted by sz3bbylA
November 26, 2021 06:32PM
I build a core xy 700x500mm
motors are 3amps nema23 with klipper and octoprint
it is not set completly
in klipper I set an delay for drivers like 3usec to eliminate posibility loosing steps
for the first prints is looking good
the problem is this layers are not alingned verticaly
one of each belt have around 5 metrs and are very long in my opinion
I left it little bit loose , I tight it , the final result is the same
can somebody tell me what can broke this aligniament ?
Re: core xy layers not aligned
November 26, 2021 11:31PM
Along which direction is the shift occurring? X, Y, 45 degrees?
Check that the drive pulleys are tight on the motor shafts.
Some photos of the printer might help.
Son of MegaMax 3D printer: [www.instructables.com]
November 27, 2021 04:32PM
the same story
is comming along x, y and 45 degree
is an core xy
I ask myself if can be from z axis
November 27, 2021 07:10PM
Pix of the printer?
The only way it could be a z axis problem is if the Z axis guide rails are not perpendicular to the XY plane defined by those axes' guide rails.
