Hello guys.
My printer stops in the middle of printing. When I use the same 3D model stops on the same layer. When I change the 3D model is what the layer it was for is different. The printer never finishes a print.
I hope you can help me, I tried to solve the problem by myself eliminating variables, but without success.
One more thing. Can anyone expline me why is the reason for in proterface recieve the values for print and travel acceleration ? On cura I turn off the option enable aceleration control and I think I resolve the problem because the 3D model is finished. But I don't now why this happen.
OUTPUT PRONTERFACE:
Setting Print and Travel Acceleration: 2000.00
Setting Print and Travel Acceleration: 1200.00
Setting Print and Travel Acceleration: 1500.00
start
echo:Marlin 1.1.0-RC8
echo: Last Updated: 2016-12-06 12:00 | Author: (none, default config)
Compiled: Mar 22 2022
echo: Free Memory: 3419 PlannerBufferBytes: 1168
Error:EEPROM checksum mismatch
[ERROR] Error:EEPROM checksum mismatch
echo:Hardcoded Default Settings Loaded
echo
teps per unit:
echo: M92 X160.00 Y160.00 Z800.00 E1674.00
echo:Maximum feedrates (mm/s):
echo: M203 X500.00 Y500.00 Z2.00 E25.00
echo:Maximum Acceleration (mm/s2):
echo: M201 X2000 Y2000 Z20 E1000
echo:Accelerations: P=printing, R=retract and T=travel
echo: M204 P1000.00 R1000.00 T1000.00
echo:Advanced variables: S=Min feedrate (mm/s), T=Min travel feedrate (mm/s), B=minimum segment time (ms), X=maximum XY jerk (mm/s), Z=maximum Z jerk (mm/s), E=maximum E jerk (mm/s)
echo: M205 S0.00 T0.00 B20000 X20.00 Y20.00 Z0.40 E5.00
echo:Home offset (mm)
echo: M206 X0.00 Y0.00 Z0.00
Mesh bed leveling:
echo: M420 S0 X3 Y3
echo: G29 S3 X1 Y1 Z0.00000
echo: G29 S3 X2 Y1 Z0.00000
echo: G29 S3 X3 Y1 Z0.00000
echo: G29 S3 X1 Y2 Z0.00000
echo: G29 S3 X2 Y2 Z0.00000
echo: G29 S3 X3 Y2 Z0.00000
echo: G29 S3 X1 Y3 Z0.00000
echo: G29 S3 X2 Y3 Z0.00000
echo: G29 S3 X3 Y3 Z0.00000
echo:Material heatup parameters:
echo: M145 S0 H180 B70 F0
M145 S1 H240 B110 F0
echo
ID settings:
echo: M301 P24.70 I2.39 D66.16
echo: M304 P97.10 I1.41 D1675.16
echo:Filament settings: Disabled
echo: M200 D3.00
echo: M200 D0
Error:Line Number is not Last Line Number+1, Last Line: 0
[ERROR] Error:Line Number is not Last Line Number+1, Last Line: 0
Resend: 1
echo
D init fail
Print paused at: 21:50:16
Edited 1 time(s). Last edit at 03/22/2022 06:26PM by Fabio3DPRINTER.
