Extruder stops after a few minutes but x,y,z continue normally April 23, 2022 09:42AM |
Re: Extruder stops after a few minutes but x,y,z continue normally April 23, 2022 11:42AM |
Re: Extruder stops after a few minutes but x,y,z continue normally April 23, 2022 12:29PM |
Re: Extruder stops after a few minutes but x,y,z continue normally April 23, 2022 06:44PM |
satellite1217
Actually, that's not a dumb question in the slightest. You're absolutely correct that that's what would happen, and I saw that a long time ago when PID values were way off. And temperature stability IS something that I could have unintentionally changed, by re-flashing the firmware because it wouldn't have kept whatever PID values it was using before the re-flash. Although I always do an auto-tune after re-flashing for exactly that reason, it may not have picked the same values that were working before the re-flash. And there are small changes we've made over the last few months that may have made it so that we were just "lucky" that the previous PID values were working and may also have made it impossible for the autotune to set values that would result in enough stability. That's a lot of "maybe"'s, but it's one theory that isn't contradicted by what we already know, so thank you! I think Marlin allows someone to widen the acceptable deviation from the setpoint. I'll try making that very large (just to test the theory.)
Re: Extruder stops after a few minutes but x,y,z continue normally April 23, 2022 09:07PM |
Re: Extruder stops after a few minutes but x,y,z continue normally April 24, 2022 11:16AM |
Re: Extruder stops after a few minutes but x,y,z continue normally April 24, 2022 03:55PM |
Re: Extruder stops after a few minutes but x,y,z continue normally April 24, 2022 09:37PM |
Re: Extruder stops after a few minutes but x,y,z continue normally April 26, 2022 09:55AM |
