Feature request
Posted by DeuxVis
Feature request
December 14, 2011 05:42AM
Hello,
Slic3r is nice. I'd like to use it more, but currently I have to apply some postprocessing to its gcode, which is a pain.
The reason is, my reprap (TZ Huxley) can only go as fast as 2mm/s on the Z axis, when the X/Y can go far faster. As I don't want to print at 2 mm/s only, I have to modify the speed of all Z movements afterwise (The fact the Z moves are separated from others helps there, please keep that).
So my request to the coder : please make it possible to set a different maximum speed for the Z axis in slic3r.
No hurry, I can continue using skeinforge in the mean time, just something nice you could make for us non-mendellers (and if that forum is not the best place for Slic3r features request, please let me know).
Thanks.
Re: Feature request
December 14, 2011 10:23AM
You should definitely limit your Z axis speed in firmware. Your firmware should be configured so that no gcode could be harmful to the mechanics of your machine.
Re: Feature request
December 14, 2011 10:56AM
I would love that, but because of what electronics/heat control I use (TZ monotronics with their custom daughter board), I'm stuck with an old modified version of 5D in which limiting speed doesn't work.
One day I'll tr yand hack that and switch to a [dr]ecent firmware, it's just a matter of time on my hands.
Re: Feature request
December 15, 2011 12:07PM
Sounds like it's time to upgrade the electronics. If you're not using RAMPS electronics and Marlin firmware, you don't know what you're missing!
Re: Feature request
December 19, 2011 05:32PM
+1 To that!
RAMPS+Marlin+Slic3r makes 3D printing a total pleasure.
[richrap.blogspot.com]
Re: Feature request
January 02, 2012 04:56AM
DeuxVis Wrote:
> please make it
> Z axis in slic3r.
Looks like that feature would also help others : [forums.reprap.org]
Re: Feature request
January 05, 2012 12:32PM
Before skeinforge implemented Z speed limiting, I believe there was a few python scrips floating around that changed the Z gcodes to a lower speed. Don't see why it should be implemented in the slic3r though, as it's clearly a issue for the firmware to solve. If it makes people take the time to upgrade their firmwares, all the better!
-Nudel
Blog with RepRap Comic
Re: Feature request
January 05, 2012 02:43PM
rhmorrison did a really great AWK script that does the job perfectly, I used it for many months (thanks Bob). it's also really easy to change and do other things with.
Find it here, [forums.reprap.org]
Re: Feature request
January 06, 2012 10:10AM
I currently use a regexp search and replace in my vi editor when I want to experiment with Slic3r.
That still is a bit annoying then - kinda defeat the otherwise great "fast and easy" enhancement that Slic3r represents over skeinforge.
Re: Feature request
January 17, 2012 04:49PM
I dont know if this has been requested yet, but how about a feature that does something like: If the layertime is < X switch on fan for that layer.
That would be awsome for small PLA layers smiling smiley
Re: Feature request
January 20, 2012 03:40PM
Just while I remember, I'm starting to miss not using jitter (Skeinforge) it would be a very neat addition to future Slic3r's
Rich.
Re: Feature request
February 01, 2012 05:34PM
Is support planned for any time soon (holding thumbs) winking smiley
Re: Feature request
February 06, 2012 05:31AM
The raft option is necessary for many users who don't have heated bed...
Re: Feature request
February 07, 2012 08:14PM
is it possible to make a feed bar so we can real time go up or down and set the speed we need in real time.
Re: Feature request
February 08, 2012 06:25AM
> real time.
This is not achievable in slic3r - has to be done in pronterface or whatever host software you use.
fma
Re: Feature request
February 08, 2012 07:04AM
Michel, this is possible (and I often do it) with EMC2...
Frédéric
