feature proposal, set time of print instead of speed
January 10, 2012 11:24AM
Usually quality of print is inversely proportional to speed. Sometime i just need a piece not perfect, and i have limited time to print it (for example because i need to sleep, or to go out).
I would love the possibility of saying to Slic3r "Do the best that you can in 2 hours". Maybe that would need the definition of maximum and minimum speeds, and it could use the actual speed settings as hints of the proportions between speeds..
It's sad that i don't know a word of perl, or i would give it a try myself..
roby
fma
Re: feature proposal, set time of print instead of speed
January 10, 2012 11:47AM
Another solution is to use emc2: it has a slider to increase/decrease the global speed. Very usefull for small layers, or, as you say, when it's time to sleep! I use that feature very often.
Maybe this could be implemented in dedicated hardwares, through a little jog?
Frédéric
January 10, 2012 11:53AM
You can't estabilish any relationship between print speeds and total time without knowing exactly the firmware acceleration parameters and the firmware acceleration logic. This is the same reason that prevents Slic3r to estimate print time.
A global speed modifier would belong more properly to the firmware or to the host software.
January 10, 2012 08:52PM
umm.. i didn't think about the acceleration problem..
so maybe a potentiometer on the machine could be enough to set a global speed coefficient.. i'll try to put my dirty hands on the firmware smiling smiley
January 12, 2012 12:48AM
I think that would better be done in the host software. It sends all the feedrates, so it could just multiply them by a factor before sending (although that wouldnt work for those thay print from SD.
January 26, 2012 03:39PM
I just had another idea of speeding up the printjob.
what if the inner (not seen) perimeters can be printed faster than the outer one ?
i don`t mean the "small perimeter" function, i mean if the outer skin is with for example 4 perimeter, the inner 3 are printed faster?
Often more perimeter are just needed because on one level of the printed part is a relative flat surface but not the rest.
or second idea would be variable perimeters, if a layer is reaching a defined angle the perimeter count will be raised some layers before ?
mfg Chri
p.s. sorry for my bad english ^^"
January 26, 2012 05:22PM
Why print more than one outline anyway? Can't get faster than that!
January 27, 2012 06:08AM
Because you get holes on very flat surfaces !
Just look at the Pictures from RichRap`s Blog
mfg Chri
January 27, 2012 06:28AM
That problem is corrected by more solid layers, you don't need more perimeters.
January 27, 2012 06:57AM
But only if the last part ist flat, what if there is at some other point in the middle such an surface ?
(for example the pink panther lady )
mfg Chri
Edited 2 time(s). Last edit at 01/27/2012 06:59AM by Chri.
January 27, 2012 07:21AM
Solid layers is not just for flat surfaces. It ensures there are always n solid layers vertically between outside and the inside.
January 27, 2012 07:48AM
Ah ok, i didn`t knew that, thx smiling smiley
mfg chri
