No extrusion!! someone help please! January 12, 2012 07:43PM |
Re: No extrusion!! someone help please! January 13, 2012 04:12AM |
Admin Registered: 17 years ago Posts: 14,050 |
Re: No extrusion!! someone help please! January 13, 2012 05:07AM |
Re: No extrusion!! someone help please! January 13, 2012 06:02AM |
Re: No extrusion!! someone help please! January 13, 2012 08:01PM |
Re: No extrusion!! someone help please! January 14, 2012 02:26AM |
Admin Registered: 18 years ago Posts: 7,883 |
Re: No extrusion!! someone help please! January 14, 2012 04:40PM |
Re: No extrusion!! someone help please! June 25, 2015 09:11AM |
Re: No extrusion!! someone help please! June 26, 2015 03:53AM |
nophead
It looks like you have your firmware E_STEPS_PER_MM set up for the old system where it was mm of extruded filament. It should be for mm of filament pulled into the extruder, which is about 36 times bigger.
You can see the E values from Slic3r are increasing by small amounts, whereas the Repsnapper E values change by the same amount as XY.
