Slic3r and pronterface
January 15, 2012 07:54AM
Hi everyone.
Could someone explain how to get slic3r to run in pronterface? I have tried a few things but I noticed I don't have the "slicing options" from the top menu?
Thanks.
Re: Slic3r and pronterface
January 15, 2012 06:31PM
scroll down to near the bottom: slic3r
regards,
Tom
January 16, 2012 05:16AM
I believe that the integration features were not merged into Printrun master branch, so you need to use the experimental one.
January 19, 2012 07:23AM
Ahh thanks for the replies, I have now got the experimental version but I dont understand the code that needs to be put into the slice command and sliceoptcommand, could someone help me with this? I am using windows btw!
January 19, 2012 11:49AM
What exactly don't you understand of it?
March 17, 2012 02:26PM
I know this an old subject but I'm new to Slic3r. So, I can't get Pronterface to work with Slic3r either. It won't accept the path and gives me this error:
Entering skeinforge settings: C:\Program Files\Slic3r --load C:\Program Files\Slic3r --ignore-nonexistent-config
Skeinforge execution failed: [Error 2] The system cannot find the file specified
Here are the 2 fieldsI have entered according to this site: [github.com]
slicecommand:
C:\Program Files\Slic3r $s --load C:\Program Files\Slic3r --output $o
sliceoptscommand:
Can anyone tell me why I still get the error?
March 17, 2012 03:27PM
None of your paths are set correctly as they all say "C:\Program Files\Slic3r".
You need to change those to reflect the complete location of slic3r and the complete location of the config file for the 2nd path.
If your paths have spaces in them then you need to use double quotes around the path name.
March 17, 2012 04:00PM
Thanks for your quick response. That is my path. It is C:\Program Files\Slic3r. but it doesn't work.
March 17, 2012 06:02PM
Is he saying you need: "C:\Program Files\Slic3r\Slic3r.exe" ?
March 17, 2012 06:25PM
Problem solved.
I needed to put double quotes around the path because I have spaces in my path names.
The follow-up qould be, does anyone know if this works with Makerbot hardware? I can't seem to connect to my machine. I am using the same port and baud rates as RepG
March 26, 2012 04:52PM
Hello
I have the same problem as you whith Slic3r in Pronterface and WINDOWS7.
I have not figured out correct spelling.Can you help me .
My path is C:\ProgramFiles(x86)\Pronterface\Slic3r\slic3r.exe
Thank you for your help and excuse my poor langage in english
Hello from France
rexty(Daniel) smileys with beer
March 27, 2012 03:37AM
Just download the latest pronterface, it has slic3r included.
April 01, 2012 07:22AM
Does anyone know the pin out assignments of the Makerbot extruder board? I've finally got printerface to communicate with my machine but when I send a heatup command, nothing happens. I can't figure out what pins should be assigned to the thermocouple. I reads the temps but doesn't heat.
April 26, 2012 09:09AM
ok - I downloaded current experimental branch of pronterface. kliment-Printrun-0dd3ce3
executed it nd wanted to change settings: I see the text "Entering skeinforge settings: python skeinforge/skeinforge_application/skeinforge.py"
but nothing more happens.
is the integration supposed to work ?
August 15, 2012 04:02PM
someone needs to post tutorials for these things
