No GCode generated for thin wall (How thin is thin??) January 30, 2012 08:01AM |
bottom_layer_speed_ratio = 0.8 bridge_flow_ratio = 1 bridge_speed = 60 duplicate_distance = 6 duplicate_x = 1 duplicate_y = 1 end_gcode = (start of end.gcode!)\nM104 S0 (extruder heat off)\nM106 (fan on)\nG91 (relative positioning)\nG1 Z+10 E-4 F400 (move Z up a bit and retract filament)\nG1 X-20 Y-20 F1500 (move X and Y over a bit)\nG90 (absolute positioning)\nM18 (steppers off)\n(end of end.gcode) extrusion_axis = E extrusion_multiplier = 1 extrusion_width_ratio = 0 filament_diameter = 2.90 fill_angle = 45 fill_density = 0.3 fill_pattern = rectilinear first_layer_height_ratio = 1 g0 = 0 gcode_arcs = 0 gcode_comments = 0 infill_every_layers = 1 infill_speed = 60 layer_height = 0.35 nozzle_diameter = 0.4 output_filename_format = [input_filename_base]_slic3r_035.gcode perimeter_speed = 50 perimeters = 3 print_center = 105,105 retract_before_travel = 2 retract_length = 1 retract_lift = 0 retract_restart_extra = 0 retract_speed = 30 rotate = 0 scale = 1 skirt_distance = 6 skirt_height = 1 skirts = 1 small_perimeter_speed = 30 solid_fill_pattern = rectilinear solid_infill_speed = 60 solid_layers = 3 start_gcode = (start of start.txt)\nM92 E836\nG21 (metric)\nG28 (home all axes to min endstops)\nG1 Z15.0 F400 (move the platform down 15mm)\nG92 E0 (zero the extruded length)\nM106 (fan on)\nG1 F75 E6\nG1 F75 E5.5\nG92 E0 (zero the extruded length again) temperature = 220 travel_speed = 150 use_relative_e_distances = 0 z_offset = 0
Re: No GCode generated for thin wall (How thin is thin??) - in 0.7.0 still present February 28, 2012 01:01AM |
Re: No GCode generated for thin wall (How thin is thin??) February 28, 2012 03:58AM |
Re: No GCode generated for thin wall (How thin is thin??) February 28, 2012 05:39AM |
Re: No GCode generated for thin wall (How thin is thin??) March 07, 2012 03:37PM |
Re: No GCode generated for thin wall (How thin is thin??) March 08, 2012 04:48AM |
Admin Registered: 12 years ago Posts: 2,569 |
Re: No GCode generated for thin wall (How thin is thin??) March 08, 2012 07:19AM |
Re: No GCode generated for thin wall (How thin is thin??) March 08, 2012 10:28PM |
Re: No GCode generated for thin wall (How thin is thin??) March 09, 2012 01:25AM |
