No GCode generated for thin wall (How thin is thin??)
January 30, 2012 08:01AM
Hi All!
First of all: Really great work! I Just started using slic3r since 0.6.0 and I find it really great!
However I have a small problem..... I designed a test object (to check several parameter on different slicer-settings) which contains a couple of thin walls (0.4, 0.5.....).
Netfabb and SF4x are slicing and printing this faily well, but 0.6.0 of slicer doesn't generate GCode for the thinner objects!
Here the STL of the object:
And here the generated GCode (settings are attached)!
How thin could be a thin wall then??
Nozzle size here: 0.4mm / Layer Height at this object: 0.35mm.
One second question:
Printed a large object with 0.35 layer height with a lot of 8mm-holes and the infill touched the hole-perimeters hardly! (Sorry, I dont' have a picture of it here atm!)
How can I influence the interconnection between perimeter and infill?
But all in all, thanks a lot for the superb work!
Best regards,
Toni
Here is the config:
bottom_layer_speed_ratio = 0.8
bridge_flow_ratio = 1
bridge_speed = 60
duplicate_distance = 6
duplicate_x = 1
duplicate_y = 1
end_gcode = (start of end.gcode!)\nM104 S0				(extruder heat off)\nM106				(fan on)\nG91					(relative positioning)\nG1 Z+10 E-4 F400	(move Z up a bit and retract filament)\nG1 X-20 Y-20 F1500	(move X and Y over a bit)\nG90					(absolute positioning)\nM18					(steppers off)\n(end of end.gcode)
extrusion_axis = E
extrusion_multiplier = 1
extrusion_width_ratio = 0
filament_diameter = 2.90
fill_angle = 45
fill_density = 0.3
fill_pattern = rectilinear
first_layer_height_ratio = 1
g0 = 0
gcode_arcs = 0
gcode_comments = 0
infill_every_layers = 1
infill_speed = 60
layer_height = 0.35
nozzle_diameter = 0.4
output_filename_format = [input_filename_base]_slic3r_035.gcode
perimeter_speed = 50
perimeters = 3
print_center = 105,105
retract_before_travel = 2
retract_length = 1
retract_lift = 0
retract_restart_extra = 0
retract_speed = 30
rotate = 0
scale = 1
skirt_distance = 6
skirt_height = 1
skirts = 1
small_perimeter_speed = 30
solid_fill_pattern = rectilinear
solid_infill_speed = 60
solid_layers = 3
start_gcode = (start of start.txt)\nM92 E836\nG21				(metric)\nG28				(home all axes to min endstops)\nG1 Z15.0 F400	(move the platform down 15mm)\nG92 E0			(zero the extruded length)\nM106			(fan on)\nG1 F75 E6\nG1 F75 E5.5\nG92 E0			(zero the extruded length again)
temperature = 220
travel_speed = 150
use_relative_e_distances = 0
z_offset = 0
open | download - ToniPruefteil_1.stl (93.9 KB)
Re: No GCode generated for thin wall (How thin is thin??) - in 0.7.0 still present
February 28, 2012 01:01AM
Hi All (especially @sound)!
I was excited about the new 0.7.0... a lot of smart features!
Unfortunately I found that the above mentioned problem still persists! Even worse, only the very right bar is sliced, and even without infill!
Any comments on that problem?? (I printed out the part again just to verify that RepetierHost doesn't show some kind of crap, but RepetierHost displays it correctly!)
Alessandro, it would be very kind if you could throw in just a couple of words on that (maby something will be solved in future versions;-)
Best Regards,
Toni
Edited 1 time(s). Last edit at 02/28/2012 01:02AM by tbaier.
February 28, 2012 03:58AM
Yes, 0.7.0 doesn't contain any work or fix with regards to thin walls so I'm not surprised things haven't changed on this issue yet. Thank you for reporting.
Edited 1 time(s). Last edit at 02/28/2012 03:58AM by Sound.
February 28, 2012 05:39AM
OK, thanks for the info!
Regards,
Toni
March 07, 2012 03:37PM
Today he met with this problem when printing prusa pulley layer of 0.2 mm
Version slic3r 0.7.0
Gear of the hollow - no fill, wall prints - one layer
Edited 2 time(s). Last edit at 03/07/2012 03:38PM by firefly.
robozone.su
open | download - pulley_slic3r_02.jpg (58.4 KB)
March 08, 2012 04:48AM
For that kind of T5 8 tooth pulley I found that with a 0.5mm nozzle you need to drop the number of perimeters to 1 single. That's not slic3r specific, this is needed for skeinforge too if you want some infill.
March 08, 2012 07:19AM
I do not think this is correct, and not just the gear, and later as a result of the experiments a lot of models or parts of them as incorrect code is generated for the thin-walled parts (not just the 0.5 mm nozzle).
sad ...
robozone.su
March 08, 2012 10:28PM
Play in Slic3r whis " Extrusion whis Ratio " !!
Test 1.2 or 1.9 !
And see its Infill
Hardwarekiller
March 09, 2012 01:25AM
Thank you very much, will try to smiling smiley
robozone.su
