STL will not slice - advice needed [SOLVED]
Posted by fredlatesta
March 24, 2012 04:50PM
I used Slic3r to slice and print a few items today and everything was perfect. Without modifying any settings, I tried to slice a part, and after "slicing" it would only generate a single layer of a dot.
I've been reading these forums, so I knew to try running it through netfabb. It would still not slice. I ran it through netfab a second time, no luck. To confirm it was not some setting, I re-sliced a simple cube, and Slic3r worked.
Just to make sure I was not insane, I opened up the STL_fixed in a viewer, and there was my part. I can not see any open mesh, or missing triangles so any advice would be great.
I am attaching both the STL after being sent to netfabb twice, and the sliced Gcode.
I am using Slic3r 0.7.1, Pronterface, Marlin 1.0, Gen6, Prusa, 0.51 mm nozzle (home made)
Sliced with a basic Windows XP laptop.
layer_height = 0.35
perimeters = 3
solid_layers = 3
fill_density = 0.25
nozzle_diameter = 0.51
filament_diameter = 2.97
extrusion_multiplier = 1
perimeter_speed = 20
infill_speed = 30
travel_speed = 80
extrusion_width_ratio = 0
scale = 1
single wall width = 0.60mm
Thank you in advance
Edited 1 time(s). Last edit at 03/24/2012 10:23PM by fredlatesta.
open | download - legotolinconadapterfixed_fixed.gcode (3.1 KB)
open | download - legotolinconadapterfixed_fixed.stl (175.5 KB)
Re: STL will not slice - advice needed
March 24, 2012 09:47PM
March 24, 2012 10:22PM
Thanks Sublime,
I would like to know how you saw that. I wasn't sure what you meant at first, but it did give me the idea to open the file again, and re-save it in Millimeters, and that fixed it.
Thanks
March 24, 2012 11:03PM
I opened it in Blender and it tells you the dimensions of the item in the item menu (press "n" until it displays a side bar next to the item). You can also try using ReplicatorG or Repitier to display, rotate and scale the part before printing.
Re: STL will not slice - advice needed [SOLVED]
March 25, 2012 08:13PM
Thanks,
I have not yet played with those tools. My software to date is netfabb (cloud) and Sketchup with a host of plugins.
The one plug in asks to save the file in (Inch, mm, Meter, ect) I must have not save it as mm.
I should try the ReplicatorG or Repitier programs.
Thanks
