Slic3r not working with this stl file
Posted by jd1828
April 11, 2012 08:46PM
I can view the stl using meshlab and it looks fine. When I try and slice it I end up getting just a single one layer circle.
open | download - bearing holder.stl (21.8 KB)
Re: Slic3r not working with this stl file
April 11, 2012 08:58PM
April 11, 2012 09:05PM
Sublime Wrote:
> Have you repaired the file? If not try running it
> through cloud.netfabb.com .
Yeah I've tried that several times.
April 11, 2012 09:10PM
Ok I download it and it is scaled incorrectly. It measures only 1.024mm x 0.709mm x 0.315mm
It may have been made and exported in Imperial units or maybe cm instead of mm's
April 11, 2012 09:27PM
Oh weird. Your right the stl has weird dimensions. I checked the original sketchup file and it's got the correct dimensions.
April 11, 2012 09:52PM
Thanks, I got it working now. No idea how that one exported like that.
