Printer goes +Z up in the air about 15cm and then wants to start printing
Posted by dustynus
May 15, 2012 02:22PM
Which setting is this in slic3r ?
My home is set 0 0 0, and the first commands of the gcode send him up 15cm above the platform and starts dripping in the center but way too high.
Thanks smiling smiley
Re: Printer goes +Z up in the air about 15cm and then wants to start printing
May 15, 2012 08:02PM
Your Z axis is likely not correctly homed or you have a very large ZOffset set in the preferences.
If it's the first issue move your Z to 0 and type G92 Z0
May 17, 2012 11:13AM
Ok I had a z-offset of 200, in the firmware I have the center being 000, so I had to customize it for my bed which has some screws in it, so I was setting it smaller to fit properly in the middle for the time being before I add a better top plate
Thanks for your help smiling smiley
