Slic3r and J-head hotends
Posted by Sublime
Re: Slic3r and J-head hotends
June 06, 2012 09:50AM
I mostly use 0.5 width and 0.2 height with my 0.35 nozzle and my prints turn out looking awesome with both makergear and arcol v4 hot-ends.
I'm currently doing some parts at 0.625 width and 0.25 layer height with my 0.35 nozzle and they're turning out perfectly with perimeters at 80mm/s and infill at 120mm/s.
I'm with nophead, nozzle diameter should only be used when bridging and setting a sensible default width. if we override width then it should be used for bridging only.
Die swell is, in my opinion, totally irrelevant when printing. During normal printing, the extruded bead is constrained in height by the layer below and the flat around the nozzle orifice, and so its width is determined solely by the volume extruded vs length of move and nozzle diameter cancels out of the math quite completely.
When bridging, this all changes. instead of calculating volume of this truncated ellipse or whatever shape the cross-section is, we calculate volume of a cylinder with diameter equal to or slightly smaller than nozzle orifice. any die swell will simply assist in stretching the bead and keeping the bridge as straight as possible.
I do not find that different heights/widths require changes in E volume calibration with either makergear or arcol v4 hot-ends.
if your hot-end can't keep up with certain settings, then either crank up the heat or use gentler settings!
A nozzle with a long orifice will give a lot of back-pressure at higher flow rates, and this will cause your hobbed bolt to push less plastic even without any actual slipping. A short orifice gives more die swell and more ooze but also allows faster printing with a smaller increase in back pressure. The arcol v4 has an orifice that's 0.5mm long last time I checked. I'm not sure how long the orifice in the J-head is but I vaguely recall hearing that it's a bit longer than that.
Wooden Mendel
Teacup Firmware
June 06, 2012 11:45AM
It doesn't affect the volume calculations but it determines how much you are stretching the filament which affects how well it bridges, how much it cuts corners and the maximum filament size you can extrude before it squirms. It is mathematically relevant whereas the nozzle diameter isn't. I.e. you can calculate the maximum filament size from it but you can't calculate anything from the nozzle diameter.
It doesn't affect the shape during bridging, just the tension. The filament will be a cylinder with a diameter defined by flow rate / feed rate ratio when it isn't constrained to be flat.
June 06, 2012 03:17PM
A bit longer would be nice. But it is much longer.
From Brian J-head blog
Budaschnozzle: 0.0095 (0.24mm)
MakerBot Mk V: 0.0515 (1.32mm)
MakerGear: 0.0335 (0.85mm)
J-Head: 0.0495 (1.26mm) It's 2.5 times longer than yours.
June 14, 2012 07:03AM
I am struggling to get inner diameters of printed holes right, using slic3r. The nominal diameter of my DIY nozzle is 0.4mm, and the mid air extrusion width is 0.75mm@300mm/min , possibly due to the very small orifice thickness. I've printed accurately with PLA with a nozzle diameter set to 0.41mm @ 130mm/s but ABS proves to be very different.
From a user's point of view, I think setting measurable values into the slicer is much preferable than playing with theoretical values that cannot be measured. Measurements that depend on other slicer settings can be used for verifying/fine-tuning of these settings:
    - Filament diameter: can be measured with calipers and averaged for non circular cross-sections. It is independent of other slicer settings.
    - Mid air extrusion@given feed rate: can be measured with calipers, independently from slicer settings.
    - Nozzle diameter: cannot be measured accurately. Independent from slicer settings. Gauging with a 0.35, 0.4, 0.5mm etc drill may yield an error in the order of 20% (e.g. a 0.49mm hole with a 0.4mm drill), so one has to use a nominal value.
    - Single wall thickness: can be measured with calipers. Depends on other slicer settings.
    - Printed perimeter thickness: cannot be measured accurately, since it is adjacent/compressed to the others or the infill and cannot be isolated. Depends on slicer settings.
    - Printed infill: ditto
    - etc
So, practically, one should be able to set filament diameter, mid air extrusion diameter and nominal nozzle diameter and choose a layer height from a range of allowable heights; the slicer then should calculate all other values based on this user input.
Any suggestion on the slic3r settings to use would be very welcome smiling smiley
June 14, 2012 07:11AM
the die swell is totally irrelevant when printing fyi, although it's loosely related to how much ooze you'll see
> settings.
except it's irrelevant so there's no point
nozzle diameter is only used for picking sensible default extrusion widths, and bridging. you don't need it accurate for 99.5% of prints.
other way around.. slic3r picks a width, you calibrate your printer to match.
slic3r uses same width as single walls with a slight (15%) overlap for strength. this doesn't push too much plastic because it calculates volume of a squashed ellipse or similar rather than a full rectangular prism when working how much plastic to use for each line.
> user input.
this already happens. slic3r has done this since its inception. except it doesn't need die swell for anything
Wooden Mendel
Teacup Firmware
June 14, 2012 08:13AM
Completely un-true. It determines the maximum filament cross section you can produce and it also determines corner radii and how much holes shrink and how well bridging works.
I already stated in the thread that I had to ream a 0.4mm J-head out to 0.45mm in order to use g-code that I previously used for a 0.4mm nozzle that had more die swell.
Die swell diameter is what is important, not nozzle diameter.
June 14, 2012 08:30AM
I frequently print with extrusion width set wider than the die swell, works fine for me.
Slic3r assumes zero die swell when bridging, so any actual die swell simply helps keep the bridge straight but doesn't show up in the math
how does it affect corner radii?
Wooden Mendel
Teacup Firmware
June 14, 2012 09:30AM
> also
> shrink
You can print wider as long as the height is not too big but you can't print with a cross sectional area bigger than the die swell area. If you do it is like pushing a piece of string. You are trying to compress the plastic instead of stretching it. It wont bridge because in free air it comes out longer than the travel. Infill droops down instead of being stretched tight and walls tend to get ripples in them as it squirms.
When I get home I can post a picture of an object printed that way because the plastic had less die swell than the plastic the gcode was sliced for.
No die swell never shows up in the maths for flow rate but neither does nozzle diameter. It is critical to bridging though as it determines how much the plastic is being stretched. It is no longer constrained above and below so it forms a cylinder with a diameter determined purely by flow rate over freed rate. The ratio of that diameter to the die swell diameter determines how much the filament is stretched. Too little and it will sag, too much and it will snap.
The more stretched it is the more it cuts the corner and the more holes shrink.
And die swell depends on speed. I slow down on small objects to keep the layer time to 20s or more. On very small objects that can result in very very slow extrusion. That can result in too little die swell and symptoms described above. An intelligent slicer would need to know how die swell varied with speed.
June 14, 2012 09:53AM
Triffid_Hunter
Well, this is a picture of my situation:
All these and more are today's calibration efforts with ABS and slic3r.
I don't get religious with software, it's there just to do the job. I've only used slic3r so far, and am happy with it. Except, in times, it can get quite difficult to setup properly.
Triffid_Hunter
I do the same while trying to achieve accurate prints. I also vary the filament diameter setting. Is there anything else I can vary?
My reasoning is that the user should not be required to fake actual measurements in order to make the software work, but rather the software should honor the actual measurements and adjust other parameters internally. The user could fiddle with slicer dependent measurements to refine the result, but not with the independent measurements.
EDIT:
I am grateful to the developer of this awesome open source software that's made slicing so fast and easy; he's already stated in this thread he's interested in the concerns expressed here so, hopefully, these comments are not out of line.
Edited 1 time(s). Last edit at 06/14/2012 12:17PM by dzach.
June 14, 2012 10:45AM
Dont want to hijack this thread so I'll be brief, I'm building my first reprap and I dont understand half of this thread but it sounds like I may want to change my mind on getting J-head. If someone can suggest a good hot ends to me by PM that wont cause me all these headaches Id appreciate it.
Thank you, and grats for the amazing developement effort, im sure there will be an update to Slic3r because of what is going on in this thread.
Edited 1 time(s). Last edit at 06/14/2012 10:46AM by thecrazy.
June 14, 2012 11:04AM
There is nothing wrong with the J-Head, it is just that Slic3r makes assumptions that are not valid.
The J-head simply has less die swell than the nozzle that the author of Slic3r uses. It is generally beneficial as it means you can extrude smaller filament for the the same size nozzle.
June 14, 2012 01:01PM
Here is a picture of my problem:
To the left is a piece with nozzle and filament sizes set to the actual nominal/measured values, 0.4mm and 1.70mm respectively with 0.25mm layers. The corner holes are designed to be 3mm in diameter and are indeed 3mm when printed as can be seen with the 3mm drill bit fitting snugly. The center hole is designed to be 22mm and take a 608Z bearing. Its printed measured diameter is 21.2mm; the bearing doesn't fit.
After fiddling with nozzle and filament diameters and other advanced parameters, I got the center hole to size, shown in the right piece. The bearing fits snugly, only, this time, the corner holes measure 4mm, way above the design size of 3mm.
It seems I cannot have the right size in both corner and center holes. Here is the STL file I'm using:
Edited 2 time(s). Last edit at 06/14/2012 01:18PM by dzach.
open | download - test.stl (38.2 KB)
June 14, 2012 02:43PM
> 3mm.
> using:
The current release of slic3r has a known bug that makes small holes to big.
June 14, 2012 03:26PM
June 14, 2012 03:41PM
richrap Wrote:
> It's fixed in the new release - 0.8.3 smiling smiley
Thanks for the heads up. When I went to look it still showed 0.8.2 until I forced a full refresh of the page.
June 14, 2012 03:55PM
It only mentions "arc compensation was applied to non-circular holes too, causing them to be too large"
What would normally happen (without compensation) is polygonal holes with small numbers of side would come out the correct size, large holes with lots of facets would shrink a little bit and small holes would shrink more.
I don't know how Slic3r can attempt to compensate because it depends on a lot of factors that it doesn't know about. The die swell for one. Perhaps one could input a small table of measurements and it could interpolate.
I prefer Skeinforge because the holes in the gcode are the same as holes in the STL. I use polyholes to get them the right size.
June 14, 2012 04:14PM
As promised earlier, a picture of an object printed where the die swell was slightly less than the extruded filament size.
The same gode printed correctly with some white ABS that had more die swell.
open | download - squirm.JPG (78.7 KB)
June 14, 2012 04:59PM
I was already using 0.8.3-dev. The problem I had still remains, I can't get all holes printed to the right sizes.
I guess I'll have to change the design to account for this problem.
June 14, 2012 05:23PM
It seems like the calculation of the size is wrong not the print. Here is a picture from pronterface's Gcode viewer:
The ratio of the center/corner holes is not what it is supposed to be, 22/3, when measuring the size of the holes on screen. Is this the way it should be?
Edited 2 time(s). Last edit at 06/14/2012 05:25PM by dzach.
open | download - slic3r.png (34.8 KB)
June 14, 2012 05:55PM
From my calculations it has made the 3mm holes 3.4mm (if the center is exactly 22) which does make sense since they tend to shrink inwards so it compensates by making them larger.
June 14, 2012 06:40PM
How did you measure it on screen? The lines are thinner than the filament because they are not touching. If you measure the circle diameter at the centre of the line then you need to subtract half the filament width. Do we know what that is?
June 14, 2012 06:42PM
I'm in two minds about a slicer changing dimensions to account for shrinkage, in principle it sounds like a good idea, but it seems to me there are two many variables for it to account for and it really ought to be done before the slicer, during modeling where you actually know what tolerances you require.
But the 3mm holes come out right. It is the 22mm one that comes out 21.3mm.
Could that be a problem of having a mid-air-extrusion / nozzle-diameter ratio close to 2?
June 14, 2012 07:31PM
I measured from outside of one side of the loops to the inside of the other side (center to center of the lines drawn by pronterface) and compared the ratio assuming the large one was modelled exactly 22mm.
Edited 1 time(s). Last edit at 06/14/2012 07:34PM by Sublime.
June 14, 2012 08:01PM
From the gcode:
; single wall width = 0.56mm
But it sure doesn't look so thin when printed.
June 15, 2012 02:57AM
this is exactly what I'd expect to see if slic3r is trying to make the 3mm holes 3.4mm in diameter and you're pushing too much plastic
I tune my plastic flow so that when I slice something at 95% fill, I can see gaps in the fill but not the solid top layers. Doing this at very low layer heights makes the difference very obvious, so can be used for fine adjustments.
Wooden Mendel
Teacup Firmware
June 15, 2012 03:46AM
I see. If I don't push too much plastic the 22mm hole will print to size but the 3mm holes will print larger due to slic3r trying to compensate, which is exactly what happened earlier, as shown in the picture. Do I have any control over this process? Has anybody else printed the test.stl successfully?
I finally gave up and changed the model to account for the shrinking of the center hole.
In any case, I thank everybody for helping me straighten this out.
Edited 1 time(s). Last edit at 06/15/2012 03:46AM by dzach.
June 15, 2012 04:10AM
You could try Skeinforge and use the Stretch module to compensate for hole shrinkage. I don't know if it works but at least everything it does is adjustable and can be disabled. Slic3r, it seems, makes undocumented and non-configurable changes to your model.
June 15, 2012 08:48AM
Thanks nophead.
I tried to set it up before, but slic3r won me over with its user friendlier GUI.
Today I'll give it another try and see how it comes out.
June 15, 2012 03:48PM
Here's another datapoint about die swell. I have recently started printing with polycarbonate. It works well with Arcol V4 but it seems to have no die swell at all. The free air extrusion is the same as the nozzle diameter (0.35), at least as far as I can measure it. With layer height of 0.225 (midpoint between 0.2 and 0.25, at which I arrived after printing ABS at both for some time) and W/T of 200%, the extrusion track cross section is very close to the cross section of the free air extrusion. Consequently, I'm getting the best overhang and corner behaviour ever. All this with standard Slic3r.
But... bridging totally sucks. The filament droops down into pretty much a hemicircle for any bridge. I have bridging speed set at 25 mm/s, half the speed of everything else, and I thought I could fix this by decreasing the bridging feed rate multiplier, but using 80% had no effect. Is it possible to get decent bridging by just adjusting the feed rate and speed multipliers, I wonder? I don't want to change the layer height or W/T, since those are such a good tradeoff between precision and speed.
