printing a perimeter layer around voids
Posted by dustynus
June 09, 2012 04:39PM
While printing a y linear bearing bracket, it prints a single layer bascially bridging around the outside through the voids for the bearing.. The following is my config for slic3r :
[i.imgur.com]
any idea?
Thanks
acceleration = 0
bed_size = 200,200
bed_temperature = 0
bottom_layer_speed_ratio = 0.3
bridge_fan_speed = 100
bridge_flow_ratio = 1
bridge_speed = 60
cooling = 0
disable_fan_first_layers = 1
duplicate = 1
duplicate_distance = 6
duplicate_grid = 1,1
end_gcode = G1 X12.0 F4000       ; home (almost) x - stops extruder crashing into frame if at very top of Z height\nG1 Y170 F4000        ; move the print to the front.\nM104 S0                   ; make sure the extuder is turned off.\nM140 S0                   ; make sure the bed is turned off.\nM84                          ; shut down motors.
extrusion_axis = E
extrusion_multiplier = 1
extrusion_width_ratio = 0
fan_always_on = 0
fan_below_layer_time = 60
filament_diameter = 1.75
fill_angle = 45
fill_density = 0.3
fill_pattern = honeycomb
first_layer_bed_temperature = 0
first_layer_height_ratio = 1
first_layer_temperature = 184
g0 = 0
gcode_arcs = 0
gcode_comments = 0
gcode_flavor = reprap
infill_acceleration = 50
infill_every_layers = 1
infill_speed = 45
layer_gcode =
layer_height = 0.12
max_fan_speed = 100
min_fan_speed = 35
min_print_speed = 10
notes =
nozzle_diameter = 0.35
output_filename_format = [input_filename_base].gcode
perimeter_acceleration = 25
perimeter_speed = 20
perimeters = 1
post_process =
print_center = 0,0
retract_before_travel = 0
retract_length = 0
retract_lift = 0
retract_restart_extra = 0
retract_speed = 40
rotate = 0
scale = 1
skirt_distance = 0.1
skirt_height = 1
skirts = 1
slowdown_below_layer_time = 15
small_perimeter_speed = 35
solid_fill_pattern = rectilinear
solid_infill_speed = 60
solid_layers = 1
start_gcode = G28                 ; home all axes\nG92 E0 ;reset extruder\nG1 E3 F1200 ;Prime extruder 3mm\nG1 E2 F1200 ;retract extruder 1mm\nG92 E0 ;reset extruder
support_material = 0
support_material_tool = 0
temperature = 184
travel_speed = 60
use_relative_e_distances = 0
z_offset = -100
Edited 1 time(s). Last edit at 06/09/2012 05:38PM by dustynus.
Re: printing a perimeter layer around voids
June 10, 2012 01:01AM
Its hard to tell from the picture but it looks like it is just ooze. Set your retract to 1mm at 15mm/s to 30mm/s depending on how fast your machine can retract.
