Print feed rate
Posted by Rein
Print feed rate
June 12, 2012 01:33AM
When I tell me machine to run a print it looks like the feed rate is not high enough. How do you change that?
The manual test extrusion feeds filiment just fine but it don't feen much (if any) when I try to run a print.
Or do you think this is an issue with the tention on the filiment in the feeder?
I'm new to this, sorry.
Re: Print feed rate
June 14, 2012 12:39PM
Guess I'll switch to Skienforge then since no one has an answer to that.
Re: Print feed rate
June 14, 2012 01:16PM
The "Extrusion Multiplier" will change the flow rate of the extruder but if it not close to 1 something else is wrong.
