When i try to slice the bolt head of [
www.thingiverse.com] i get a crash.
Slicing C:\Reprap\STLs\Bolt Pencil Case\BoltHead.stl
Slicing: Slic3r/slic3r.exe $s --load Slic3r/config.ini --output $o
=> Processing input file
=> Processing triangulated mesh
=> Generating perimeters
=> Detecting solid surfaces
=> Preparing infill surfaces
=> Cleaning up
=> Detect bridges
Then i get a dialog about Microsoft Visual C++ Runtime Library
Can someone try slicing that to see if it is a bug, or is it my settings somehow?
If you can slice it i will give you my settings and see if you crash with them.
BTW Window Vista Home running under pronterface.
thanks
SteveMac
