slic3r is not geometrically correct June 18, 2012 02:53PM |
Re: slic3r is not geometrically correct June 18, 2012 03:06PM |
FFF Settings Calculator | Gcode post processors | Geometric Object Deposition Tool Blog |
Tantillus.org | Mini Printable Lathe | How NOT to install a Pololu driver |
Re: slic3r is not geometrically correct June 18, 2012 03:20PM |
Admin Registered: 17 years ago Posts: 7,879 |
Re: slic3r is not geometrically correct June 18, 2012 04:39PM |
Re: slic3r is not geometrically correct June 18, 2012 04:42PM |
Re: slic3r is not geometrically correct June 18, 2012 04:49PM |
Re: slic3r is not geometrically correct June 18, 2012 05:06PM |
Re: slic3r is not geometrically correct June 18, 2012 05:10PM |
Re: slic3r is not geometrically correct June 18, 2012 05:20PM |
Re: slic3r is not geometrically correct June 18, 2012 05:22PM |
Re: slic3r is not geometrically correct June 18, 2012 05:24PM |
Re: slic3r is not geometrically correct June 18, 2012 05:36PM |
Re: slic3r is not geometrically correct June 21, 2012 09:31AM |
Re: slic3r is not geometrically correct June 21, 2012 02:52PM |
Re: slic3r is not geometrically correct June 21, 2012 03:02PM |
Re: slic3r is not geometrically correct June 21, 2012 03:21PM |
Re: slic3r is not geometrically correct June 21, 2012 04:41PM |
Re: slic3r is not geometrically correct June 21, 2012 05:57PM |
Re: slic3r is not geometrically correct June 21, 2012 06:22PM |
Re: slic3r is not geometrically correct June 21, 2012 06:35PM |
Re: slic3r is not geometrically correct June 23, 2012 12:34PM |
Re: slic3r is not geometrically correct June 23, 2012 04:18PM |
Re: slic3r is not geometrically correct June 24, 2012 12:04AM |
Re: slic3r is not geometrically correct June 24, 2012 11:39AM |
Re: slic3r is not geometrically correct June 24, 2012 01:46PM |
Re: slic3r is not geometrically correct June 24, 2012 04:50PM |
nophead, you wrote that you'd like to change some hard-coded things in Slic3r. Can you explain them?
Re: slic3r is not geometrically correct June 24, 2012 05:27PM |
