unable to slice that !
Posted by jf pion
June 25, 2012 03:41PM
hello
with 8.4 i tried to slice the joined stl ( from thingiverse, scaled down and re meshed with meshlab to lower the size of the stl (the full size doesn"t work ethier)
without support it sliced it quickly but with a lot of geometrical abberation, with support it fail during the "generating support phase)
hope this help
open | download - Klein_Bottle_Table_Lamp_-_Math_Art_by_Dizingofsmall.stl (401.1 KB)
Re: unable to slice that !
June 25, 2012 03:43PM
June 25, 2012 04:23PM
Yes it was generated with meshlab
and the original from thingiverse, the scaled down one verified with nettfab can't be sliced with the support generation
June 25, 2012 05:50PM
I am not sure what you are trying to achieve but I can't see what you uploaded as ever being printable in its current state. You need to separate all the pieces and print them one at a time.
Edited 1 time(s). Last edit at 06/25/2012 05:50PM by Sublime.
open | download - Klein_Bottle_Table_Lamp_-_Math_Art_by_Dizingofsmall.resized.png (127.9 KB)
June 26, 2012 03:32PM
that"s a try to reduce the size of the stl with meshlab, not really sucessful
, the original part is here :
[www.thingiverse.com]
and slicer can't slice it with the support even after netfab (first thing I do know, lesson well learn)
to bad i find it nice
June 26, 2012 04:08PM
If I were trying to print that I would make my own support by importing the original into a modelling program and make a cylinder with a 1mm wall that sat under the floating part as only the one edge needs support by the look of it.
June 26, 2012 05:06PM
i will try
do you try to slice it even with no support ?
it work with 0.4 layer but not with 0.2 or 0.1 with no error message and no gcode generated
June 26, 2012 05:14PM
jf pion Wrote:
> i will try
I did not try but that sounds like it is running out of memory. Try having your system monitor open when slicing and see if your memory gets all used up.
June 27, 2012 12:09AM
Sublime Wrote:
That's exactly what I see when I open that .stl file. I don't see how it could ever get through Slic3r properly, much less end up with printable gcode.
Edited 1 time(s). Last edit at 06/27/2012 12:09AM by NewPerfection.
Help improve the RepRap wiki!
Just click "Edit" in the top-right corner of the page and start typing.
Anyone can edit the wiki!
June 27, 2012 01:57AM
NewPerfection Wrote:
> Sublime Wrote:
> [forums.reprap.org]
> lename=Klein_Bottle_Table_Lamp_-_Math_Art_by_Dizin
> gcode.
that's a try to reduce the stl size to post it here, not really sucessful
did you try the original file from thingiverse ?
June 27, 2012 02:04AM
> up.
just did
win 7 8 GB of ram, slicer give up with no warning still 1.8 GB free during infill layer phase
look like a bug
hope this help
