if its strength youre after you can try this-
1- set infill to 30% or so and rectlinear leaving significant gaps in the grid.(30% infill resulted in a grid spacing of about 2.5mm in this example)
2- set solid infill for every 4 or 5 layers (assuming about .2 layer hieght)
3- set bridge flow ratio to 2
4- check "infill before perimeters"
the "bridge" function will become active and extrude material down into the 3 previous layers. this makes the part nearly impossible to delaminate and the carbon/ABS I am using at the moment is incredibly stout using this technique. adjust 2 or 3 to keep layer height at the right height. if the nozzle is dragging increase # 2 or decrease # 3 and vise-versa. I am getting supper clean prints doing this.
I need to find out what activates "bridge". and for that I will start a new topic
Edited 1 time(s). Last edit at 04/27/2014 05:27PM by Bill Clark.
