Settings drop down menu too small
Posted by isotone
May 21, 2014 06:38AM
Hi, Firstly thanks for the great program!
One problem that I am starting to have is that I have a lot of different settings, some with quite long names, and I cannot see the end of them as there is no tooltip on the dropdown boxes or way to widen the relevant UI column. So I have to select two identical settings and check which is which manually, which is annoying.
Anything I've missed or help on this appreciated.
cheers
Rich
Re: Settings drop down menu too small
May 21, 2014 08:40AM
This is a user forum not necessarily read by developer, you may address your request here instead:
[github.com]
