Feature request: different layer with/(and height?) for infill ?
Posted by Chri
June 29, 2012 07:13AM
Hy guy`s
I`m printing with a 0,3mm nozzle and noticed that i can also print 0,5mm width with it without problems (for example at 0,2mm layer height)
my thought was to change the the width of the infill for speeding up the printing process ?
or even make a feature like Skeinforge`s "Skin" to do two layer perimeter on the outside but only one big Layer of Infill on layers that don`t change.
This should speed up the printing process of large objects a lot ?
mfg Chri
Re: Feature request: different layer with/(and height?) for infill ?
June 29, 2012 12:32PM
There is already a setting "Infill Every N Layers" which does this. If you set your layer height to 0.2mm and set this value to "2", it will infill using 0.4mm layers.
June 29, 2012 01:06PM
Oh okay, i thought the "infill every N Layers" make a normal full infill every "N" Layer , so i never tried its grinning smiley
thx
mfg Chri
