Skic3r 0.8.4 possible bug
Posted by MotoBarsteward
June 29, 2012 07:17AM
I'm printing a standard calibration part and slic3r is not making the correct geode. It appears to be thinking that the extrusion width is zero when printing the outside perimeter of an object. I think it may also be making the same mistake when printing holes. When I print an object that is 10mm wide, what I get is an object that is 10mm + the extrusion width. I have raised an issue on github. Can some one please verify what I am saying. Gcode before for printing the perimeter (2 shells) of something that is 22mm wide. My extrusion width is 0.26mm.
G1 X80.683 Y94.697 F270.000 E2.14912
G1 X80.683 Y75.343 E2.28429
G1 X102.035 Y75.343 E2.43342
G1 X102.035 Y94.661 E2.56833
G1 X102.338 Y95.000 F7800.000
G1 X80.380 Y95.000 F270.000 E2.72169
I have spent two days trying to fiddle with setting to remove the error but have not succeeded and, having looked at the geode, I thing slic3r is at fault. I've not noticed this before because my printing has only just got good enough to make this discrepancy repeatable.
Using ABSPrusa Mendel Zaphod with Pronterface and slic3r 1.3.0. Printing well with 3mm PLA and ABS through 2 x J Head Mk IV b and Wade Geared Exruders. Controlled using RAMPS1.4 board running Marlin_v1.1.9
Re: Skic3r 0.8.4 possible bug
July 01, 2012 02:39PM
Can someone please test this for me. Please print, using slic3r 0.8.4 and Pronterface the following object. It's a 1cm wide slot and a 1cm peg. When I print it, the beg is too large for the hole. In fact, the peg is one extrude width (look in the gcode file) too wide and the slot is one extrude width too narrow.
Perimeter test
You may need to fix it with cloud.netfabb.com
Let me know what you find.
July 01, 2012 09:58PM
Printed. Sorry, I don't use Pronterface, but I used: ABS, Greg's with .35 J-Head, Slic3r, Repetier host & frimware
Small block I measured at 10.0mm wide, slot is 9.75, but I can force it in.
Edited 1 time(s). Last edit at 07/01/2012 10:04PM by Dad911.
Thingiverse ID Alan1279
open | download - photo(1).JPG (417.6 KB)
July 02, 2012 01:56AM
Thanks, I think the issue is with slic3r. Is that what you used for slicing? I think maybe not?
July 02, 2012 04:09AM
I used slicer 8.4.
July 04, 2012 01:37PM
I printed your perimeter-wt-stl (perimeterwt_fixed.stl) three times. Here are the print results:
a) Pronterface + Slic3r V.0.8.4
block = 10.4 mm, slot = 9.3 mm
b) Pronterface + Slic3r V0.8.3
block = 10.3 mm, slot = 9.4 mm
c) Pronterface + Skeinforge
July 04, 2012 03:47PM
> print results:
that's weird because the size of the STL in netfab is 10.01 mm for the slot and 9.98 for the block
but it coherent with a bug i just reported [github.com]
Re: Skic3r 0.8.4 possible bug - Fixed by github issue #495
July 04, 2012 04:37PM
Thanks for doing this, flurin. A bu has been found in slic3r 084. I'm testing the fix now.
Adjusted my Extrusion Multiplier to 0.87 as my extrusion width was coming out at 0.64 when is should have been 0.56.
And...
Slot = 9.96mm
Peg = 9.98mm
Problem solved.
This fix will go into the next release of slic3r, 0.8.5 I suppose.
Edited 1 time(s). Last edit at 07/04/2012 04:38PM by MotoBarsteward.
July 07, 2012 02:35PM
I tried to print this:
[www.thingiverse.com]
and found that the dovetail tabs are too big to fit in the slots by about a mm.
Is this the same issue?
(I ground them down and epoxied everything together, so no harm no foul, but this does seem like a bug in 0.8.4
-Rob A>
July 07, 2012 02:38PM
> like a bug in 0.8.4
> -Rob A>
The Bug adds 0.1mm to all outer walls. So if your print is 1mm to large then Slic3r 0.8.4 is only part of the problem the rest is your calibration or extrusion multiplier.
July 08, 2012 03:51AM
@Sublime
As far as I know the filament diameter and the Extrusion multiplier are used to calculate the plastic volume. Some people use the extrusion multiplier to correct the volume. But the reason is the diameter, therfore I usually measure the filament diameter several time and set the value e.g. 1.7 instead of 1.75 and don't change the extrusion multiplier.
Edited 1 time(s). Last edit at 07/08/2012 04:24AM by flurin.
