hello, okay?
I've been researching the option Complete Individual objects.
I came to some conclusions:
1 - You need to check the "complete individual objects", put the radius and the height of the nozzle print.
2 - you need to put the most distant objects
3 - Manually inserting two objects in the "place" of slic3r, tab it works correctly.
4 - the repetier host does not work because: to send to slic3r he joins the multiple objects turning into a single STL. From what I read this bastard does this to improve processing. But just spoiling the sequential printing
5 - using the same version of Repetier 1:00 Slic3r RC2 version 1.1.6 and the integration between the two does not work
From what I understand communication between Repetier Slic3r and is made for a file and the AMF Slic3r not understand the divisions into groups of objects that are made in Repetier
My question:
Is there any way to make the Repetier Host and Slic3r to communicate and operate the sequential printing?
I spoke at the forum Repetier Host this link:
github.com]
But so far got no solution by the Repetier
follows a print of situation:
the first image I slice in Slic3r and copied the gcode to repetier
the second image I slice directly in repetier using slic3r
grateful
Edited 1 time(s). Last edit at 07/30/2014 08:27PM by GuilhermeGasperin.
