brim feature request - brim height.
July 02, 2012 07:26PM
brim is awsome, I'd been using loops prior to brim.
unfortunately for low layer heights, one layer brim is just not enough. we need a brim height, either in layers or mm.
fma
Re: brim feature request - brim height.
July 03, 2012 01:44AM
What is brim?
Frédéric
July 03, 2012 04:42AM
It's a kind of skirt that touches the perimeter and is multiple extrusions wide. Looks like Saturn rings touching the planet to me.
Some people had nice result using that to fight warping, so its auto generation has been included in the last slic3r version.
Somebody also made a skeinforge plugin modification to generate it.
And there is an openscad module to generate it at the stl level.
See topic [forums.reprap.org]
July 03, 2012 05:33AM
If you generate it at the STL level it wont peel off as the infill will extend into it. It will need to cut off and will leave a ragged edge.
fma
July 03, 2012 06:20AM
Thanks, guys! I will give it a try...
Frédéric
August 01, 2012 11:32PM
Does anyone know anything about this plugin/modification. I prefer to use skeinforge for my slicing, but there are times when brim can be useful. I find it easier to remove and less wasteful of filament while at the same time it helps the print to adhere.
August 02, 2012 05:33PM
I use brim all the time when I slice. it's very good.
August 06, 2012 07:03AM
Last version I know about is here : [forums.reprap.org]
Works fine for me, but you should still keep a backup copy of your original skirt.py file.
