pb with multiple part on the plater
Posted by jf pion
July 03, 2012 08:59PM
when I tried to slice 4 parts from [www.thingiverse.com] 0.4 layer 0.5 nozzle 5mm brim i got the joined image of the gcode
a bit messy isn't it ?
the stl export went fine and the atomatic slice from pronterface with slicer went fine too
but the direct slice to gcode with the 4 stl files not
a bug i think !
open | download - plieurs.PNG (13.9 KB)
Re: pb with multiple part on the plater
July 04, 2012 04:21AM
You should try without the brim, that recent feature is possibly the bugger here.
July 04, 2012 05:04AM
as I said the stl export worked fine making one stl with all the parts and the slicing of the fusionned stl worked fine too so i could print without pb
anyway this is a bug with an easy go around, but a bug so I report it
