Can't print with Pronterface with Slic3r July 04, 2012 06:55AM |
Re: Can't print with Pronterface with Slic3r July 04, 2012 07:08AM |
Admin Registered: 14 years ago Posts: 2,569 |
T:75.42display is the hotend temperature. Does it go higher than what you shown us ?
Re: Can't print with Pronterface with Slic3r July 04, 2012 06:34PM |
Re: Can't print with Pronterface with Slic3r August 07, 2012 07:45PM |
Re: Can't print with Pronterface with Slic3r August 07, 2012 07:51PM |
| FFF Settings Calculator | Gcode post processors | Geometric Object Deposition Tool Blog |
| Tantillus.org | Mini Printable Lathe | How NOT to install a Pololu driver |
Re: Can't print with Pronterface with Slic3r August 12, 2015 11:46AM |
Re: Can't print with Pronterface with Slic3r August 15, 2015 06:50AM |
Re: Can't print with Pronterface with Slic3r August 15, 2015 08:05AM |
Re: Can't print with Pronterface with Slic3r August 15, 2015 05:52PM |
the_digital_dentist
...Slic3r is very good but a little buggy. Sometimes it works and sometimes it doesn't and it takes a little experience to know when the problems it creates are caused by slic3r and when they are printer problems. Try Cura instead. It is easier for a noob and very reliable. There are fewer confusing options to set, and if you have problems with a Cura sliced file not printing it is either because you set one of the few options incorrectly or your printer is having a problem, not because of Cura misbehaving...
Re: Can't print with Pronterface with Slic3r August 15, 2015 07:11PM |
Re: Can't print with Pronterface with Slic3r August 17, 2015 08:03PM |
