any body can help plz September 29, 2014 07:30AM |
Re: any body can help plz September 29, 2014 09:15AM |
Re: any body can help plz September 29, 2014 09:31AM |
Re: any body can help plz September 29, 2014 12:59PM |
dmould
The G-code will depend on the slicer setting required by your particular printer, so it is not possible to create a g-code file for you without knowing what settings your printer needs. It sounds like you need to rotate the part to get the correct surface flat onto the bed. I am not familiar with Sketchup, but I expect it will allow you to rotate the part. If not you can export an STL and load it into Cura or another slicing program that allows you to rotate in X or Y axis (I think Slic3r only allows rotation around Z).
I cannot use your .skp file (as said, I don't use sketchup), but if you would like to post the STL that Sketchup exports, I can rotate it using OpenScad to an orientation suitable for loading into the slicing program used by Proterface (probably Slic3r).
Dave
Re: any body can help plz September 29, 2014 01:02PM |
QuackingPlums
There were multiple items in your .skp file. I'm guessing you want the 2D 'flat' version of it like this?:
[attachment 41214 Logotiabauniversity.stl]
Re: any body can help plz September 30, 2014 03:33AM |
Re: any body can help plz September 30, 2014 05:47AM |
Re: any body can help plz September 30, 2014 05:54AM |
ThorsenRune
Omar, for sketchup I use stl4su.rb plugin. You will download it from [github.com]
Its very easy then to just export the sketchup to a stl file.
Re: any body can help plz September 30, 2014 08:50AM |
Re: any body can help plz September 30, 2014 09:53AM |
Re: any body can help plz October 12, 2014 09:29AM |
Re: any body can help plz October 13, 2014 04:36AM |
Re: any body can help plz October 13, 2014 03:47PM |
Re: any body can help plz October 14, 2014 06:45AM |
Re: any body can help plz October 19, 2014 05:09PM |
Re: any body can help plz October 20, 2014 07:20AM |
